Key fob won't start car - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: Key fob won't start car (/showthread.php?tid=26004) |
Key fob won't start car - Nathan1305 - 17-08-2014 I know another key fob thread but I can't find the answer I'm looking for, basically the key with the buttons won't start my car. The remote central locking works fine. I did a re sync and got it to work and start the car and thought great it's working. But I've just gone out to start it and it won't start with the fob key. I have to re-sync it every time. Is there any way to permanently fix this? It's a IR fob. All help is appreciated
RE: Key fob won't start car - cully - 17-08-2014 the key has 3 parts part 1 IR buttons this only controls the locking unlocking and alarm set unset can be synced by yourself part 2 Immo chip the Immo chip ether works or dont this is what unlocks the ecu/pump this can only be programed with pp2000 or cloned into another chip by people with the hardware part 3 key blade mechanical lock unlock and ign barrel RE: Key fob won't start car - Niall - 17-08-2014 As cully says, the immobiliser chip is unrelated to the IR chip which means the "resync" isn't actually related to the immob chip at all. I would imagine its one of several things; Bad pick up ring Bad chip - can be cloned into a new one by Timpsons assuming their machine can read it Chip isn't in the correct place in the case - if its just been jammed in somewhere, it may only just be close enough to the pick up ring RE: Key fob won't start car - Nathan1305 - 17-08-2014 (17-08-2014, 07:41 PM)Niall Wrote: As cully says, the immobiliser chip is unrelated to the IR chip which means the "resync" isn't actually related to the immob chip at all. I would imagine its one of several things; Hmm this sounds expensive :/ so why when I re-sync it, it starts but forgets it after the car is locked. Is this to do with the chip? RE: Key fob won't start car - glan2014glan - 26-08-2014 T300 Key Programmer English/Spanish 2013 Version http://www.obd2works.com/t300-key-programmer-englishspanish-2013-version-blue-p-1818.html
