low hanging exhaust - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: low hanging exhaust (/showthread.php?tid=25791) |
low hanging exhaust - philpemberton94 - 07-08-2014 The bend in the centre section on my dt sits very low, probably no more than 4 inches off the ground, making it almost impossible to go over soeed bumps without scraping it, the car has been lowered 30mm on the front but nothing on the back, any one had the same problem and know the best way to fix it? Cheers! RE: low hanging exhaust - Danny2009 - 07-08-2014 Slacken of the clamp on the backbox/downpipe rotate the centre section so it's closer to the body and re clamp RE: low hanging exhaust - philpemberton94 - 07-08-2014 Ahh right just need rotating! Will give it a whirl when i get home Cheers! RE: low hanging exhaust - Danny2009 - 07-08-2014 That's all I have ever done when there sagging either that or new rubbers RE: low hanging exhaust - WiNgNuTz - 07-08-2014 My hdi had both symptoms. Knackered rubbers, and the clamp between the decat and mid section was only finger tight, letting the whole system sag and twist. Nipped that up, and 3 new rubber hangers, jobs a good'un!
RE: low hanging exhaust - Toms306 - 07-08-2014 Hmm, wonder if this is the issue with mine. The backbox hits the beam constantly while stationary which is really annoying, but the tip is about 8" lower than it should be so cant see how I could lower any of it!
RE: low hanging exhaust - Iceman299 - 07-08-2014 I had a decat fitted last week and now the midbox hits the undersidewhen i turn left. Looked underneath and found the pipe sagging pretty low between mid and backbox, need to get it adjusted his week RE: low hanging exhaust - philpemberton94 - 08-08-2014 Was just a matter of rotating it haha sits nicely now so can actually go over speed bumps! RE: low hanging exhaust - silverzx - 08-08-2014 Heavy duty zip ties on the rubber mounts to lessen movement/vibration also help. |
