Sub, Amp and Wiring - £50 at FCS? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Parts (https://www.306oc.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: Sub, Amp and Wiring - £50 at FCS? (/showthread.php?tid=23346) |
Sub, Amp and Wiring - £50 at FCS? - bigcheez2k3 - 18-04-2014 Full setup here to get some bass in your car. JBL 1000 watt sub in box with JBL amp. Wiring kit from the car, correct lengths for 306. 4awg, I think, power and earth cables. Was in my car but took it out after 4 days as I decided I wanted to hear my engine and that I'm past bassy music in the car. Can even throw the board for the boot in if you like. I had it bolted to this to keep it stable. £75. Collection from South London. Might be going Ace on monday so could bring it with me. RE: Sub, Amp and Wiring - DeeTurbo - 18-04-2014 Got any pics of it and is it a 10" or 12"? RE: Sub, Amp and Wiring - bigcheez2k3 - 18-04-2014 It's a 10". Also come with a remote level control for the amp, forgot to mention. Amp model is a JBL GTO 3501. One of the RCA connectors will need soldering back on as it came off while removing the wiring from the car earlier. I did have a go but our soldering iron isn't great. Edit: think I have a spare set that could go with it. ![]()
RE: Sub, Amp and Wiring - bigcheez2k3 - 22-04-2014 Bump. RE: Sub, Amp and Wiring - Eeyore - 22-04-2014 This is the same sub I have. Would recommend. RE: Sub, Amp and Wiring - bigcheez2k3 - 05-05-2014 Bump. RE: Sub, Amp and Wiring - Slam Wagon - 05-05-2014 Got the 8" version, great little subs. RE: Sub, Amp and Wiring - mcglynn - 06-05-2014 Same sub I have only I've a 4 channel amp bridged running it. Sounds well RE: Sub, Amp and Wiring - bigcheez2k3 - 17-05-2014 Bump. Sub, Amp and Wiring - Ben Jay - 18-05-2014 Bring this to ace with you please... RE: Sub, Amp and Wiring - bigcheez2k3 - 30-05-2014 £50 at FCS? RE: Sub, Amp and Wiring - £50 at FCS? - bigcheez2k3 - 05-06-2014 Bump. |
