Xud acting like limp mode - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Xud acting like limp mode (/showthread.php?tid=20766) |
Xud acting like limp mode - Daniel306 - 24-01-2014 Fitted a TD04 turbo engine that was in a 205 into my 306, it was running fine untill i turned the boost up from 1.2 to 1.5 using a MBC, once it hits about 1.3 the boost drops to zero and will stay there until i release the throttle, during this time it will not change Rpm. i was thinking it was the MBC or the wastegate jamming open but i have changed both and its still the same There is no odd noises or leaking that i can hear, iv now fitted a Hks electronic controller and it sometimes reads -11 or -.11 Hgmf(or whatever the unit vacuum is measured in) RE: Xud acting like limp mode - darrenjlobb - 24-01-2014 Your sucking an intake pipe in on itself. Collapsing. RE: Xud acting like limp mode - darrenjlobb - 24-01-2014 Need better pipes on the intake side of turbo. Run open turbo to test and I bet it will be fine
RE: Xud acting like limp mode - Daniel306 - 24-01-2014 Il give it a try, 10/10 if its correct and im sure it will be RE: Xud acting like limp mode - Daniel306 - 24-01-2014 Would a cone foam filter cause this, foam collapsing making it denser? RE: Xud acting like limp mode - Tom - 24-01-2014 A f*cking clogged up one would. How big is your inlet piping? |
