Wheel Hub/Knuckle - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Wheel Hub/Knuckle (/showthread.php?tid=20313) |
Wheel Hub/Knuckle - Marcus1991 - 10-01-2014 Hi, Does anyone know if the hub/knuckle from a phase 2 dturbo will fit on a phase 1 dturbo? Thanks. RE: Wheel Hub/Knuckle - Toms306 - 10-01-2014 The ball joint hole might be a different size, but apart from that I believe they're the same. RE: Wheel Hub/Knuckle - powerandtorque - 10-01-2014 If your car has ABS you'll need to check that the replacement hub is an ABS type (preferably with an undamaged sensor as they're often difficult to remove without damaging them and genuine Bosch replacements aren't cheap) |
