gti 6 cutting out - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: gti 6 cutting out (/showthread.php?tid=19345) |
gti 6 cutting out - wibbz - 05-12-2013 Hi all hope someone can help me here I have a gti 6 and sometimes when I. Coming to a stop while breaking the car will cut out it has also done it a few times when I have gone round a few corners tbe car will fire straight back up it has had new idle controle valve fitted a few months ago many thanks wibbz RE: gti 6 cutting out - Piggy - 05-12-2013 idle control valve common fault I believe but the going round bends is odd....enough fuel?? is there an intank strainer on the '6? RE: gti 6 cutting out - Grant - 05-12-2013 He has said he has replaced the ICV.... Was it an OE quality part? Do you know what make? Are you in an engaged gear when this happens? RE: gti 6 cutting out - cully - 05-12-2013 did you clean out the plastic port on the manifold when you changed the ICV? RE: gti 6 cutting out - Matt - 05-12-2013 Made sure all pipes are connected properly to icv and the bolts are tight. The I ring in place on it properly? I know I snagged mine once and it would seem like I had a faulty icv RE: gti 6 cutting out - wibbz - 05-12-2013 Thanks for your responses guys it was a icv from a local motor factors I will double check all bolts and pipes again as for the fuel I never have it below quarter of a tank RE: gti 6 cutting out - Paul_13 - 05-12-2013 Reset the ecu Can work wonders! RE: gti 6 cutting out - Matt - 05-12-2013 ^^ and that, did you reset the ecu after fitting the new parts? After I fitted an icv, with out resetting, it would idle at 2k or stall haha RE: gti 6 cutting out - puglove - 06-12-2013 It could be the ICV again if its just a cheapo one. Alot of people have had problems with cheap ones only last a very short time. |
