Any citroen 1.4i owners... - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Any citroen 1.4i owners... (/showthread.php?tid=1896) |
Any citroen 1.4i owners... - Poodle - 01-03-2012 I'm trying to sort the timing on a xsara 1.4i and cant find the flywheel locking hole for the life of me, anyone got amy ideas..? Cheers Re: Any citroen 1.4i owners... - Dan! - 01-03-2012 Tried behind the starter motor? I think thats where they are on most PSA engines... Re: Any citroen 1.4i owners... - Connor - 01-03-2012 That'd have been my guess too^^ Re: Any citroen 1.4i owners... - Poodle - 01-03-2012 Starter motor is on the back of the block on this one, anything that's not obscured by the motor is just open to the flywheel... There's 3 holes that could be it on the front of the block, one large and two small. There's nothing on the flywheel that matches up to the larger hole - can see it quite easily - and as far as i can tell it's the same with the smaller ones too. I tried keeping pressure on a 5mm allen key in both holes while turning the engine over and didn't get anywhere, turned it over 3 times for each hole just to make sure, but nothing. WTAF?? :x Re: Any citroen 1.4i owners... - Connor - 01-03-2012 ![]() 5+6 are the locking pins, looks like it should be on the flywheel to me Re: Any citroen 1.4i owners... - Poodle - 01-03-2012 Farking legend, nice one mate cheers. Re: Any citroen 1.4i owners... - Rippthrough - 01-03-2012 Some of the early flywheels just have an indent rather than a hole. Re: Any citroen 1.4i owners... - Poodle - 01-03-2012 Sorted, got the missus to turn it over while i was looking for the hole, found the bugger eventually. Damn thing was exactly the same size as the allen key i was trying to find it with, slightly the wrong angle and it skated past, which at least explains why i couldn't work it out earlier. :roll: Cheers for the help dudes, Connor you've got some rep reserved for when Scott and Foobs get their shizzle sorted. Re: Any citroen 1.4i owners... - Connor - 01-03-2012 Oh yeah, getting your missis to help find the hole....bet she does that alot...
Re: Any citroen 1.4i owners... - Poodle - 02-03-2012 Only if she doesn't want a surprise...
