mot time..... veg oil+petrol - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: mot time..... veg oil+petrol (/showthread.php?tid=18831) |
mot time..... veg oil+petrol - Chris_90 - 13-11-2013 So my car has got petrol and Veg Oil mix in the tank will it be ok for mot? Or will it mess with the emissions? RE: mot time..... veg oil+petrol - Mattcheese31 - 13-11-2013 just turn max fuel down if you're worried . .
RE: mot time..... veg oil+petrol - silverzx - 13-11-2013 It should be fine, just restrict/adjust the throttle cable so it's nice and slack. Or turn the max fuel down a few turns (if on a bosch). Other then that no reason why it should fail. It's smoke density right? Not emission based. RE: mot time..... veg oil+petrol - Chris_90 - 13-11-2013 No idea tbh it hardly smokes on the Veg any way it's just a haze so should be ok, guess we will find out when it goes RE: mot time..... veg oil+petrol - silverzx - 13-11-2013 I'd be suprised if you failed. RE: mot time..... veg oil+petrol - Chris_90 - 13-11-2013 (13-11-2013, 11:33 AM)silverzx Wrote: I'd be suprised if you failed. Just booked it in for Friday so will see pretty sure it will fail on something probably not emissions if you guys think it's ok RE: mot time..... veg oil+petrol - Andy annear - 13-11-2013 i enquired about this when i motd my car running 100% veg, they didnt have a clue and just said bring it in, it initially failed on over 2x the legal limit which i couldnt believe as it only just smoked on boost. So i just turned down the fuel screw infront of them and it went straight through. But as a fuel it shouldnt make a difference
mot time..... veg oil+petrol - ben87 - 13-11-2013 I ran my in veg oil turned, restricted the accelerator cable and passed no problem RE: mot time..... veg oil+petrol - r3k1355 - 13-11-2013 Veg usually burns a whitish grey, Diesel burns black. Veg registers alot lower in emissions as it's seen as being much less dense smoke. Mine often reads really high on the first pass, then subsequent readings are much lower. Always a good idea to give it an Italian Tune-up on the way to the test
RE: mot time..... veg oil+petrol - Chris_90 - 13-11-2013 It's just the petrol in mix that I'm worrying about if that will mess it up, not to worried about the veg oil RE: mot time..... veg oil+petrol - Tom - 13-11-2013 I didnt even downtune mine, passed easily. RE: mot time..... veg oil+petrol - bigcheez2k3 - 13-11-2013 Never done anything with mine either, passed just fine except for an advisory once for 'black smoke'
RE: mot time..... veg oil+petrol - Chris_90 - 14-11-2013 As said further up its not the Veg Oil I'm worried about its the petrol in the mix RE: mot time..... veg oil+petrol - Piggy - 14-11-2013 well with petrol burning cleaner than diesel or veg...whats the problem? RE: mot time..... veg oil+petrol - Jonny81191 - 14-11-2013 (14-11-2013, 07:27 AM)Chris_90 Wrote: As said further up its not the Veg Oil I'm worried about its the petrol in the mix And most people have said it's fine.. Good hard pull a couple of times on the way to the MOT, although from what I understand, they'll generally give it a damn hard rev prior to the smoke test anyway. In other words, don't worry! RE: mot time..... veg oil+petrol - Chris_90 - 14-11-2013 (14-11-2013, 07:32 AM)Piggy Wrote: well with petrol burning cleaner than diesel or veg...whats the problem? Didn't no petrol burnt cleaner than derv!! I no Veg does but not petrol thanks for clearing that up captain sarcasm ![]() (14-11-2013, 07:32 AM)Jonny81191 Wrote:(14-11-2013, 07:27 AM)Chris_90 Wrote: As said further up its not the Veg Oil I'm worried about its the petrol in the mix Ok cool thanks will give it a good thrash clear it out abit
RE: mot time..... veg oil+petrol - WiNgNuTz - 14-11-2013 Last MOT, I didnt adjust mine, but i just scraped through....the limit is 1.50 whatever its measured in, and mine made 1.49! I also took mine out half hour before it was due for the MOT, and just went for a spirited drive, delivered the car to them with a lovely warm engine, and they literally drove it straight in and did the test.
RE: mot time..... veg oil+petrol - Paul Baldwin - 15-11-2013 My 106 was MOT'd two weeks ago running on 95% veg 5% petrol. Emissions were well within limits. The only complaint from the tester was the smell giving him the munchies. RE: mot time..... veg oil+petrol - silverzx - 15-11-2013 (15-11-2013, 02:13 PM)Paul Baldwin Wrote: My 106 was MOT'd two weeks ago running on 95% veg 5% petrol. Emissions were well within limits. The only complaint from the tester was the smell giving him the munchies. This haha! RE: mot time..... veg oil+petrol - Chris_90 - 15-11-2013 We'll it's just got back from mot passed not sure if this means any thing to u guys ![]() No idea what it means but it passed so all good decide if I'm keeping it now
RE: mot time..... veg oil+petrol - silverzx - 15-11-2013 You flew through. RE: mot time..... veg oil+petrol - Tom - 15-11-2013 Easy peasy! RE: mot time..... veg oil+petrol - r3k1355 - 18-11-2013 See, told you veg gets you a lower score. Mine went thru fine this weekend too, didn't get a emissions report tho. RE: mot time..... veg oil+petrol - Daniel306 - 18-11-2013 1.5 1/m The test limit should be 3.0 1/m, thats what all my Mots say RE: mot time..... veg oil+petrol - Chris_90 - 18-11-2013 (18-11-2013, 04:28 PM)r3k1355 Wrote: See, told you veg gets you a lower score. I no Veg Oil is lower on the emissions but as I said a few times in this thread it was the petrol in the mix I was worried about |
