15psi in neutral? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: 15psi in neutral? (/showthread.php?tid=18806) |
15psi in neutral? - LewisG306 - 12-11-2013 Hi all , This may be a bit of a noob question and me not thinking it through properly but is there any obvious reason why my car should make 15psi in neutral? revving up to around 4 grand it gets there. Running a de-wastegated td04 , gov'd and ground lda bosch etc. you all know the details already no doubt. Just curious guys... Cheers RE: 15psi in neutral? - Mattcheese31 - 12-11-2013 why wouldn't it? RE: 15psi in neutral? - LewisG306 - 12-11-2013 I'm still learning so i dont know lol , im guessing they're not like petrols that make boost only under load? RE: 15psi in neutral? - londondan86 - 12-11-2013 You will see boost in neutral but peek boost will only appear under full load RE: 15psi in neutral? - LewisG306 - 12-11-2013 ahh right i think i get it now haha RE: 15psi in neutral? - Dave - 12-11-2013 Does it actually hold the boost if you hold at 4k.... It's not normal if it sustains it but quick spikes of throttle will draw enough flow to build the boost momentarily. RE: 15psi in neutral? - Mattcheese31 - 12-11-2013 (12-11-2013, 01:41 PM)Dave Wrote: Does it actually hold the boost if you hold at 4k.... It's not normal if it sustains it but quick spikes of throttle will draw enough flow to build the boost momentarily. what he said^^^^ . . .
RE: 15psi in neutral? - LewisG306 - 12-11-2013 (12-11-2013, 01:41 PM)Dave Wrote: Does it actually hold the boost if you hold at 4k.... It's not normal if it sustains it but quick spikes of throttle will draw enough flow to build the boost momentarily. Ive not tried holding it , i dont really like doing it haha. and ahh okay |
