Anyone with a 1.8 16v... can you help? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Anyone with a 1.8 16v... can you help? (/showthread.php?tid=18449) |
Anyone with a 1.8 16v... can you help? - laurence_13 - 29-10-2013 Still looking for a sump, just been out and had a look at the part number (9631935780) from what I can make out, googled it, and it came back as a citroen berlingo sump for a 1.8 8v. Has it been replaced with a citroen sump or are they just both the same... if anybody could check theres, I'd be greatful! Cheers Laurence RE: Anyone with a 1.8 16v... can you help? - Toms306 - 29-10-2013 Its the same block for the 1.8 8v and 16v as far as I know, so the sump should be the same.
RE: Anyone with a 1.8 16v... can you help? - laurence_13 - 29-10-2013 (29-10-2013, 09:14 PM)Toms306 Wrote: Its the same block for the 1.8 8v and 16v as far as I know, so the sump should be the same. Ahh nice one, they look the same from the outside, just want to make sure the internals sit right. Are they exchangeable from peugeot to citroen then... or are they the same engine? Excuse my ignorance...
RE: Anyone with a 1.8 16v... can you help? - Toms306 - 29-10-2013 Yup, its the same engine, XU7 is the code. Used by both Peugeot and Citroen in many different cars and vans.
RE: Anyone with a 1.8 16v... can you help? - laurence_13 - 29-10-2013 (29-10-2013, 09:48 PM)Toms306 Wrote: Yup, its the same engine, XU7 is the code. Used by both Peugeot and Citroen in many different cars and vans. Ideal, thankyou very much! RE: Anyone with a 1.8 16v... can you help? - miles - 29-10-2013 Alloy or Steel? I have alloy ones here, GTi6 versions but they all still fit the same, even 1.6 205's are fine Dead easy to collect too RE: Anyone with a 1.8 16v... can you help? - laurence_13 - 30-10-2013 (29-10-2013, 11:44 PM)miles Wrote: Alloy or Steel? Alloy just ordered one, should be here tomorrow... Cheers though!
