Not quite a 306 - 206 1.1 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: Not quite a 306 - 206 1.1 (/showthread.php?tid=17769) |
Not quite a 306 - 206 1.1 - burnmw - 03-10-2013 I've got to change the throttle valve body on my little brothers 206, can anyone tell me if the white socket on the bottom is for anything important? As you can see, the one I've bought to replace it doesn't have the socket on the bottom. RE: Not quite a 306 - 206 1.1 - 306Dan - 03-10-2013 If all the other plugs work take the white one out of the old body cut a hole in the air pipe or box and put it in there RE: Not quite a 306 - 206 1.1 - Piggy - 03-10-2013 I would think air temp sensor. it will want it RE: Not quite a 306 - 206 1.1 - burnmw - 03-10-2013 Cheers both, just had the thought to check ServiceBox, the top one has the air temperature probe, the "new" one is from a depoll vehicle and doesn't. |
