Dodgy GTI 6 Bottom Pully - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Dodgy GTI 6 Bottom Pully (/showthread.php?tid=17052) |
Dodgy GTI 6 Bottom Pully - PUGNUT_XS - 05-09-2013 Greetings all. Been stripping down my 6 engine. i have seen the threads about the bottom pully going out of line because the rubber wears, Timed the engine up and the bottom pully was way off, on the crank pully there is some paint marks, so i went off that. i assume that if i was to buy a new bottom pully that would resolve the problem? Does anybody know who produces a GTI 6 workshop manual, as i only have the standard peugeot haines one. RE: Dodgy GTI 6 Bottom Pully - Ed Doe - 05-09-2013 Hi mate, common problem for that to happen, well done catching it before you did any damage. Lynx Power Engineering do single-piece lightweight billet pulleys for a fairly resonable price; be rude not to upgrade whilst you're at it
RE: Dodgy GTI 6 Bottom Pully - cully - 05-09-2013 excellent catch! could of been an expensive mistake RE: Dodgy GTI 6 Bottom Pully - Niall - 05-09-2013 If you look on the pulley, there is two small arrows that should line up. If they dont, your pulley is fooked. Either go for a light weight single piece one or just get a new one from ECP or similar. RE: Dodgy GTI 6 Bottom Pully - PUGNUT_XS - 05-09-2013 (05-09-2013, 04:35 PM)Niall Wrote: If you look on the pulley, there is two small arrows that should line up. If they dont, your pulley is fooked. Either go for a light weight single piece one or just get a new one from ECP or similar. Cheers i will check that tomorrow, i saw a warning on my autodata. Euro car parts do one for 47+ the dreaded. RE: Dodgy GTI 6 Bottom Pully - C2K - 09-09-2013 Buy a RichW one solid pulley. Peugeot engine manual available on GTi6 owners, from here http://www.mediafire.com/?yyoztk2wdyz. Not sure if it works, i'm in the office and mediafire is banned. RE: Dodgy GTI 6 Bottom Pully - PUGNUT_XS - 09-09-2013 C2K. Many thanks for the link. Just what i was looking for
RE: Dodgy GTI 6 Bottom Pully - MCH - 06-10-2013 Good spot! I would just change for a rich w pulley if you're changing it anyway, its lighter and wont slip either! I'd never refit a standard type if changing bottom pulleys... |
