Stainless cat back exhaust for track days - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Stainless cat back exhaust for track days (/showthread.php?tid=16993) |
Stainless cat back exhaust for track days - mtp - 03-09-2013 Is anyone running a stainless cat back exhaust system that isn't too load for track days. My standard gti exhaust is rotting between the centre pipe and back box. I want to put a stainless system on but need to stay below 92db. I know there are a few to choose from but struggling to find out how load some of them actually are. My standard one measured at 79db at 3500rpm on the last track day. RE: Stainless cat back exhaust for track days - vlj - 03-09-2013 Vote on Mongoose! sure Sean will too RE: Stainless cat back exhaust for track days - Midnightclub - 03-09-2013 Scorpion /endthread RE: Stainless cat back exhaust for track days - Just Sean - 03-09-2013 Not a chance Danny! Mongoose ftw! Mines a magnex decay with mongoose cat back and I was 87db @ 4500rpm
RE: Stainless cat back exhaust for track days - Midnightclub - 03-09-2013 Was it still blowing at the centre when that was done though sean? gas needs to come out the back you know
RE: Stainless cat back exhaust for track days - Ed Doe - 03-09-2013 Mongoose FTW! RE: Stainless cat back exhaust for track days - mtp - 03-09-2013 Thanks for the suggestions. Looks like noise is not a problem if you get 87db with a mongoose and decat. RE: Stainless cat back exhaust for track days - Grant - 03-09-2013 Frankenstein straight through FTW! RE: Stainless cat back exhaust for track days - mtp - 03-09-2013 (03-09-2013, 11:33 AM)Midnightclub Wrote: Was it still blowing at the centre when that was done though sean? gas needs to come out the back you know Will have to remember this trick at the next noise test
RE: Stainless cat back exhaust for track days - Just Sean - 03-09-2013 Its still blowing Tbf . need to get some welding done RE: Stainless cat back exhaust for track days - mtp - 03-09-2013 Mines beyond welding ![]() Good reason to upgrade though
RE: Stainless cat back exhaust for track days - cully - 03-09-2013 Mines at 91db @4500 with a stainless longlfe system with just a backbox if i remember coombe has a limited of 95db so mines a bit close hence why no track time on the 14th RE: Stainless cat back exhaust for track days - Just Sean - 03-09-2013 I thought come was 99 RE: Stainless cat back exhaust for track days - mtp - 03-09-2013 (03-09-2013, 12:36 PM)cully Wrote: Mines at 91db @4500 with a stainless longlfe system with just a backbox Longlife systems are made to order aren't they. A mate of mine had one on his MR2, said the quality was really good. RE: Stainless cat back exhaust for track days - Just Sean - 03-09-2013 And Cully that's a rubbish excuse Tbf ... You need to man up! RE: Stainless cat back exhaust for track days - cully - 03-09-2013 (03-09-2013, 01:15 PM)Just Sean Wrote: And Cully that's a rubbish excuse Tbf ... You need to man up! cars not really ready for a track slot have things still i want to check over and change ready for a track day ![]() it will happen though when the car is ready and not before RE: Stainless cat back exhaust for track days - miles - 04-09-2013 £380.00 retail for a CAT back system of mine, All well proven on all of my and customer's 306's |
