306 1.9d estate modified - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Cars (https://www.306oc.co.uk/forum/forumdisplay.php?fid=21) +--- Thread: 306 1.9d estate modified (/showthread.php?tid=16805) |
306 1.9d estate modified - baz306 - 26-08-2013 hi guys just testing the water the now car runs amazing lowered 55mm front 50mm rear fk shortened shocks front and rear fully recond axle with new hubs/bearings and stub pins new rear axle bushes new rear brake pipes from front to back new rear brake hoses 2 new rear brake cylinders 2 new rear abs sensors 2 new front drop links 2 new track rod ends new front drivers abs sensor upgraded gti6 brake calipers new 283mm gti6 brake discs new gti6 brake pads new auxillary belt top tensioner and spring pipercross panel induction filter custom air intake inlet manifold sealed with high temp silicone gasket upgraded sony speakers front and rear headlights masked black new front washer jets new aeroflat window wipers back window dewipered under car all treated and undersealed 406 v6 16 inch alloys dressed with 195/45/16 accelera tyres front laguna splitter cut to bumper size stainless exhaust 2 new wishbones bad points passenger wing needs painted roof needs painted as i removed the roof bars and a small patch on the bumper needing painted looking for £700 mot'd till next june and taxed till december only done 80 odd thousand miles new car forces sale might break if i get enough interest 306 1.9d estate modified - djdommyp - 05-09-2013 Have you got any pics ? Thanks RE: 306 1.9d estate modified - silestanix - 14-09-2013 Locations and as above, pics mate? |
