smooth boot - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: smooth boot (/showthread.php?tid=16789) |
smooth boot - sam - 25-08-2013 How easy is it to smooth a boot? And is it best to get to get it welded were the boot lock/pop used to be? RE: smooth boot - DazzaHDI - 25-08-2013 Make sure its a ph3 boot mate otherwise youll get a massive rust bubble under the rubber seal like mine has :/ RE: smooth boot - sam - 25-08-2013 Mine is a phase 3 chap but ill keep that in mind chap
RE: smooth boot - kingy - 25-08-2013 Im looking into this. Deffo get it welded. Much better. My problem is the popper and how to wire it in. I can remember dum doing a guide for this but he just used bubbly gum to fill his hole. But hey if it works then it works. RE: smooth boot - Piggy - 25-08-2013 just need a centrol locking servo motor, earth it, and then run a positive feed to it from a switch inside. Re: RE: smooth boot - kentiiboii - 25-08-2013 (25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. One sat at mine with popper just needs painting. RE: smooth boot - kingy - 26-08-2013 (25-08-2013, 11:04 PM)kentiiboii Wrote:(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. Ill have it mate. 100%. How much? RE: smooth boot - DazzaHDI - 26-08-2013 (25-08-2013, 11:04 PM)kentiiboii Wrote:(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. I was going to have that off you? You didn't reply to my question about collection? RE: smooth boot - Grant - 26-08-2013 I did a guide a while ago. It wasnt welded, but it never budged and inch. clicky RE: smooth boot - C.A.R. - 26-08-2013 Mine was welded, I can't take credit for it, but I did wire up the popper, much easier than you'd expect, probably took less than an hour and that included running a signal wire from the boot hatch, down the C-pillar and to the control panel on the drivers side of the car. Hook it up to permanent live though, or you have to f*ck about turning the ignition on to open your boot. Re: RE: smooth boot - kentiiboii - 26-08-2013 (26-08-2013, 06:56 AM)kingy Wrote:(25-08-2013, 11:04 PM)kentiiboii Wrote:(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. Pmd (26-08-2013, 08:54 AM)DazzaHDI Wrote:(25-08-2013, 11:04 PM)kentiiboii Wrote:(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. Sorry mate just checked my pms back till last year havnt seen anything but sorry RE: smooth boot - DazzaHDI - 26-08-2013 (26-08-2013, 03:21 PM)kentiiboii Wrote:(26-08-2013, 06:56 AM)kingy Wrote:(25-08-2013, 11:04 PM)kentiiboii Wrote: One sat at mine with popper just needs painting. YHPM http://306oc.co.uk/forum/thread-15083.html RE: smooth boot - 306newbie - 29-09-2013 you could also just use some fiberglass from behind to hold a metal plate in place then a little skim of filler on the outside RE: smooth boot - Piggy - 30-09-2013 (29-09-2013, 11:29 PM)306newbie Wrote: you could also just use some fiberglass from behind to hold a metal plate in place then a little skim of filler on the outside can't see the benefit of fibreglassing a piece of metal in to only fill/skim over when you may aswell just fill over the fibreglass!?
RE: smooth boot - Eeyore - 30-09-2013 there is a guide. just put the popper on the rear wiper wiring. best and easiest way really! |
