EGR... - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: EGR... (/showthread.php?tid=16735) |
EGR... - E_KEL95 - 23-08-2013 The EGR on my HDi is still all connected up, just wondering is it a hard job to: 1. Blank off the EGR & 2. Clean all the soot thats built up because of the EGR Have next week off and was gona set about doing this to the car always meant to. RE: EGR... - titch - 23-08-2013 Have a look here mate. http://306oc.co.uk/forum/thread-13047.html RE: EGR... - Leedunn86 - 23-08-2013 Its relatively straight forward, you'll need to remove the top elbow if you want to remove all the soot and gunk, get some strong degreaser as its horrible stuff left mine soak in a bucket while i cleaned up the engine bay. Hardest bit for me was removing the clip on the hose at the bottom of the elbow as someone had put it back on at a weird angle not hard just fiddly. RE: EGR... - E_KEL95 - 23-08-2013 What all needs to come off exactly? And would making a home made blanking plate do the job outta a bit of sheet metal? RE: EGR... - Leedunn86 - 23-08-2013 Need to remove the air box and pipework then undo the 2 bolts on the top of the inlet elbow and also the 2 allen bolts on the egr side watch you dont loose the metal gasket as it will drop out the bottom. Then undo a bracket and the clip that holds the elbow to the bottom hose, should come out with some wiggling then. Yea should be able to diy the blank seen cut up coke cans used in the past, just use the metal egr gasket as a guide. Once thats all cleaned and reassembled, you'll need to disable the egr itself theres a guide in the section to do this |
