XU injector nozzles - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: XU injector nozzles (/showthread.php?tid=16713) |
XU injector nozzles - jammapic - 22-08-2013 Hi all, Does anyone know where I can get hold of a set of conical spray nozzles for a set of stock XU injectors? Obviously they have a split spray pattern for firing direct at the valves on the stock motor. The setup I'm currently running has the injector sat much further away so a split spray is not required. Thanks, JP RE: XU injector nozzles - emmerce - 27-08-2013 Let me ask a quastion - are you not looking for injectors, but only conical spray nozzles? I've never heard about this kind of modernization, how should it work? |
