hi and help - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: Newbies (https://www.306oc.co.uk/forum/forumdisplay.php?fid=24) +--- Thread: hi and help (/showthread.php?tid=16349) |
hi and help - tomr45 - 10-08-2013 hi im in neet of some help i'v got a 1.0 turbo derv 405 ive just done the head gasket water pump and timeing belt kit i'v done over 1000 miels since i did them and the cars been spot on but went to start the car last night and there was a nock the car now sturs over but the only seems to b compression on 1 cyinded and ext is comimg from the inlet ive have checked the timing and everthing lines up the only thing ive done is i changed the cam box gasket then it did this ive checked the cam carryers where the cam box bolts to and there is nothing rong tar tom RE: hi and help - Grant - 10-08-2013 Welcome ![]() I can't read much sense of that I'm afraid. Stick some punctuation in an try again
RE: hi and help - Herby7 - 10-08-2013 Welcome RE: hi and help - Dum-Dum - 24-08-2013 Welcome along mate. Try posting your issue in the XUD section (I'm assuming you meant 1.9 TD) and maybe split your post into sentences to make it a little easier to understand. |
