Can I cut these off? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Can I cut these off? (/showthread.php?tid=16152) |
Can I cut these off? - rtha6551 - 03-08-2013 trying to remove my front bumper to put my splitter on, and the 3 bolts on the underside of the bumper with the long 'tabs' are rusted but spin freely without loosening off can I just saw them off? Or will it make the bumper less secured to the body? RE: Can I cut these off? - cwspellowe - 03-08-2013 Just f*ck them off. None of my bumpers have ever had them. RE: Can I cut these off? - Danny2009 - 03-08-2013 Will make the bottom less secure but as pellowe said be fine without them RE: Can I cut these off? - Eeyore - 03-08-2013 My bumpers did have them... now they dont... #reversing #toolow Can I cut these off? - rtha6551 - 03-08-2013 Might just gaffer tape them back together after, should do the trick Abandoned ship anyway as its started to piss it down -.- RE: Can I cut these off? - Danny2009 - 03-08-2013 So it is Ffs got to walk home soon! Just cut them off closest to the nut then make a hole in the tabs and cable tie them round the lower cross member job done RE: Can I cut these off? - cully - 03-08-2013 the bumper will sag and drop over time if you cut them off you will get a big panel gap between the bonet lion and the bumper as the bumper twist down RE: Can I cut these off? - underground375 - 03-08-2013 This happened to me, I solved it by drilling the threaded end out then buying replacement bolts, washers and nuts one size smaller then the old ones. Job done
RE: Can I cut these off? - Grant - 03-08-2013 Just f*ck em off. I've never had any on any of the 6 front bumpers I've had fitted. If you are that worried then make a new bracket with some metal bar and self tappers. Can I cut these off? - rtha6551 - 04-08-2013 (03-08-2013, 10:11 PM)Grant Wrote: Just f*ck em off. I've never had any on any of the 6 front bumpers I've had fitted. I'm going to be taking my foglights out anyway and they're flaked inside so I might sacrifice them by cutting the fixing brackets off and using them as new bumper brackets
