abs light still on - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: abs light still on (/showthread.php?tid=15188) |
abs light still on - baz306 - 03-07-2013 hi guys after fitting 3 brand new abs sensors to the car the abs light is still on brand new hubs on the back so a know the teeth are fine and i checked the abs rings on the front and they are fine any idea what could be wrong RE: abs light still on - Grant - 03-07-2013 Tried cleaning the ABS rings up front? Sometimes the sensors struggle to pick them up correctly if they are caked in shit. Get a multimeter on the plugs for the ABS sensors and either spin a wheel (manually when the car is jacked up) or wave a magnetic screwdriver over the tip of the sensor and check for resistance. RE: abs light still on - Piggy - 03-07-2013 Just curious why you have so far changed 3 sensors?....IE, what led you to do that and why not all 4!? RE: abs light still on - baz306 - 03-07-2013 (03-07-2013, 02:03 PM)Piggy Wrote: Just curious why you have so far changed 3 sensors?....IE, what led you to do that and why not all 4!?front one was snapped the other one was a new one before a got the car recon'd axle on the back and couldnt get the old ones out the old axle (03-07-2013, 02:02 PM)Grant Wrote: Tried cleaning the ABS rings up front? Sometimes the sensors struggle to pick them up correctly if they are caked in shit. on the rear abs sensors a had to cut the pin down a gd bit in order for the abs sensor to go in as the pin was far too long and hittin against the hub could it be anything to do with that its still pretty close to the hub RE: abs light still on - daddyfixit - 03-07-2013 you cut it ?.............you killed it then. RE: abs light still on - Piggy - 03-07-2013 you cut the sensor?! Oh crap. that maybe ya issue!
RE: abs light still on - baz306 - 03-07-2013 had to the pin was far too long theres still a bit of pin the gap between the pin and the hub is about 2mm from the hub
RE: abs light still on - baz306 - 03-07-2013 am taking it down to my mate tomorrow for an mot so a will just get him to sort the abs out RE: abs light still on - baz306 - 03-07-2013 was the pin circled that i gave a wee trim RE: abs light still on - baz306 - 04-07-2013 abs was fine lol a forgot to plug in one of the sensors my bad thats it passed its mot only advisory was balljoint had very very minor play
