hdi fmic - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: hdi fmic (/showthread.php?tid=13446) |
hdi fmic - hdi shaun - 01-05-2013 Been searching into the fmic on a 306. Can see it all looks simple to do but....... Fitting the bottom pipe am i suppost to rotate the comppressor side to fit the bottom hose Its ok found some more info... Good old search button :-) RE: hdi fmic - Midnightclub - 01-05-2013 If you come to the Weston meet you can have a look at Emma's HDi, that's stage 2 RE: hdi fmic - hdi shaun - 02-05-2013 Whens the weston meet chap RE: hdi fmic - Midnightclub - 02-05-2013 12th of may bud
RE: hdi fmic - hdi shaun - 02-05-2013 Sweet just after japfest. RE: hdi fmic - Dum-Dum - 02-05-2013 (01-05-2013, 09:04 PM)hdi shaun Wrote: Fitting the bottom pipe am i suppost to rotate the comppressor side to fit the bottom hoseNope it points down, leave it alone. If you use a 90* 41mm silicone and a "C5 bottom pipe" it'll run nicely under the engine between the sump and the box. RE: hdi fmic - Midnightclub - 02-05-2013 ^ that, or you can use a 406 pipe and no 90 degree bend but it's a much sharper angle on the pipe and not good for air flow |
