lda hat removal (screws nit torx issue) - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: lda hat removal (screws nit torx issue) (/showthread.php?tid=13312) |
lda hat removal (screws nit torx issue) - dturbine - 28-04-2013 Built an 11 mm pump and decided to do the lda mods aswell came to remove the top and its stuck... Has the flat bladed screw type. I tried a penny ajd 20p in the slot and bent them... RE: lda hat removal (screws nit torx issue) - Ricky - 28-04-2013 Try a small chisel and a hammer. RE: lda hat removal (screws nit torx issue) - londondan86 - 28-04-2013 I used mole grips on mine then changed them for bolts RE: lda hat removal (screws nit torx issue) - Tom - 28-04-2013 I used impact driver lol RE: lda hat removal (screws nit torx issue) - Oil-burner - 28-04-2013 Mole grips ftw! Thats how I did mine! lda hat removal (screws nit torx issue) - Jake - 28-04-2013 (28-04-2013, 10:11 PM)Oil-burner Wrote: Mole grips ftw! Thats how I did mine! If this doesn't work just use still-sons. RE: lda hat removal (screws nit torx issue) - Mal - 28-04-2013 Impact driver, then change to bolts ![]()
RE: lda hat removal (screws nit torx issue) - Tom - 28-04-2013 I have that exact impact driver, works great! |
