HDI standard straight through? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: HDI standard straight through? (/showthread.php?tid=12733) |
HDI standard straight through? - jackmiller30 - 11-04-2013 I'm going to be cutting open my cat later, stripping it out and then welding it back together, as for the back silencer can i just cut this open and rip the insides out and weld it back together or is it better to do a mid box conversion? Jack RE: HDI standard straight through? - Poodle - 11-04-2013 Much of a muchness tbh, performance-wise. RE: HDI standard straight through? - Franko - 18-04-2013 Can you not hammer a spike straight through the cat and shake the guts out?.. RE: HDI standard straight through? - E_KEL95 - 18-04-2013 Take al th boxes out lad, gona do it do it right! RE: HDI standard straight through? - Poodle - 18-04-2013 You can beat it out, yeah. Definitely the more labour intensive option though, took ages to get the stuff broken up enough to get it all out. RE: HDI standard straight through? - Eeyore - 18-04-2013 (18-04-2013, 08:09 PM)Franko Wrote: Can you not hammer a spike straight through the cat and shake the guts out?.. you wont get it all out like that. All you do is just put a hole through the filter. Loose stuff also rattles around and annoys you. Best to cut it open and get it all out properly and then seal it back up! RE: HDI standard straight through? - jackmiller30 - 19-04-2013 I ended up choping the cat, emptying then welding it back, same with the rear silencer - the rear silencer was a b****! RE: HDI standard straight through? - puglove - 19-04-2013 (19-04-2013, 11:45 AM)jackmiller30 Wrote: I ended up choping the cat, emptying then welding it back, same with the rear silencer - the rear silencer was a b****! Is much easier to just put a bit of straight pipe where the back box should be. much better and easier & 100% legal (18-04-2013, 08:17 PM)E_KEL95 Wrote: Take al th boxes out lad, gona do it do it right! If your going to give people advice like that you need to male them aware it is illegal and a MOT failer !! RE: HDI standard straight through? - E_KEL95 - 19-04-2013 (19-04-2013, 11:59 AM)puglove Wrote:(19-04-2013, 11:45 AM)jackmiller30 Wrote: I ended up choping the cat, emptying then welding it back, same with the rear silencer - the rear silencer was a b****! They must be while simple if they didnt already know! RE: HDI standard straight through? - puglove - 20-04-2013 not particalarly not everyone knows that you need atleast 1 silencer. oh a write in english for f*ck sake RE: HDI standard straight through? - HDIkyle - 21-04-2013 (18-04-2013, 08:17 PM)E_KEL95 Wrote: Take al th boxes out lad, gona do it do it right! Too right! I did mine in stages. Hammered cat out and straight pipe back. Then got middle box removed then fitted front ecar pipe. Later was by far better both performance and noise We used a long bar down the end to smash it up. If you take your time we get the whole lot out so nothing to rattle about |
