Another "Help" Torsion Bar Thread! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Another "Help" Torsion Bar Thread! (/showthread.php?tid=12687) |
Another "Help" Torsion Bar Thread! - 306Brad - 09-04-2013 In the progress of lowering the 306 and ive hit a brick wall.. Removed the ARB - OK Removed the passenger side offset washer -OK Drivers side offset washer seized - Not OK! Anyone got any tips on how youve removed seized offset washers? p.s its drowned in WD40 & ive cleared as much dirt as I can.. Next step would be a blowtorch? Also ive been trying to bash it out with a screwdriver and hammer.. No luck! Any tips appreciated! RE: Another "Help" Torsion Bar Thread! - Niall - 09-04-2013 Sounds stupid i know but your knocking it out the right way yeah? When they are full of crud, it can be difficult to see what side of the hole has the recess in. RE: Another "Help" Torsion Bar Thread! - 306Brad - 09-04-2013 Deffo knocking it the right way Niall, 100%! Just dont budge down or wiggle at all.. RE: Another "Help" Torsion Bar Thread! - Niall - 09-04-2013 get a bit of heat on it then. RE: Another "Help" Torsion Bar Thread! - 306Brad - 09-04-2013 Will try that next.. Anyone had this problem and solved it? RE: Another "Help" Torsion Bar Thread! - Arron - 09-04-2013 Might have to take the trailing arm off bud RE: Another "Help" Torsion Bar Thread! - 306Brad - 09-04-2013 Really don't wana do that but if heat and a shed load more penetrating fluid wont do it ill have too.. Just cant get the bugger to move!! RE: Another "Help" Torsion Bar Thread! - Arron - 09-04-2013 Thats what they had to do with mine bud RE: Another "Help" Torsion Bar Thread! - 306Brad - 09-04-2013 Gahhh! Going to blowtorch the shit out of it and see if i get anywhere. Re: Another "Help" Torsion Bar Thread! - floz123 - 09-04-2013 I had this exact problem on Sunday!! On the same side. Ended up drowning it wd40 but found there was no room to swing a hammer. Eventually I used a small chisel and hammer but hit it in all directions to loosen it up...including hitting it face on. Would have used a blowtorch but didn't have mine to hand. Took about an hour to get it out. Good luck man...be brutal! Lol (and try not to wedge anything inside the hole in the washer as it damages the thread in the torsion bar. Another "Help" Torsion Bar Thread! - JamesG - 09-04-2013 Blowtorch then spray wd40 to cool it down and keep doing that till finally It will pop out
RE: Another "Help" Torsion Bar Thread! - 1616six - 09-04-2013 plusgas is your friend
RE: Another "Help" Torsion Bar Thread! - cwspellowe - 09-04-2013 And then when you've put everything back together, fill the place with silicone to stop it filling with crap again, so next time you need to adjust the height you can just pull the silicone plug out and boom, easy removal of the washer Another "Help" Torsion Bar Thread! - Parksy87 - 09-04-2013 (09-04-2013, 07:57 PM)cwspellowe Wrote: And then when you've put everything back together, fill the place with silicone to stop it filling with crap again, so next time you need to adjust the height you can just pull the silicone plug out and boom, easy removal of the washer Im glad im not the only one that thought of this :p RE: Another "Help" Torsion Bar Thread! - Chris_90 - 09-04-2013 Ive had this problem every time spent hours and hours trying to get it lots of different ways nothing worked bought some plus gas 30seconds later couple of taps and was out plus gas really does work!, RE: Another "Help" Torsion Bar Thread! - miles - 09-04-2013 Air Chisel works wonders, But not generally a DIY tool, so the large hammer and chisel is the next best thing, Next are the bar's RE: Another "Help" Torsion Bar Thread! - puglove - 10-04-2013 you need a really thin screw driver keep cleaning it. Also sounds stupid but you'd be suprised how many people do it. you are using a solud metal punch and not a old srew driver or chisel with a plastic/wood handle? as any thing with a handle will take out alot of the shock from the hammer making it alot less efferlctive? Another "Help" Torsion Bar Thread! - 306Brad - 10-04-2013 Wow didn't expect this many decent replies, cheers fellas! Tempted to dremel the **** out if gas doesn't work! Time is on my side though so will keep bashing at it! Yepp using a solid metal punch! Will update with progress at the weekend. RE: Another "Help" Torsion Bar Thread! - Piggy - 10-04-2013 (10-04-2013, 07:11 AM)306Brad Wrote: Wow didn't expect this many decent replies, cheers fellas! thats what you get here...many replies
Another "Help" Torsion Bar Thread! - 306Brad - 10-04-2013 Forgot how involved the French scene is! Also love how the answer to most problems is a large hammer haha RE: Another "Help" Torsion Bar Thread! - Matt - 10-04-2013 (10-04-2013, 07:19 AM)306Brad Wrote: Forgot how involved 306oc is! Also love how the answer to most problems is a large hammer haha Edited that for you fella
Another "Help" Torsion Bar Thread! - 306Brad - 10-04-2013 (10-04-2013, 07:32 AM)Matt Wrote:Haha I was on 106oc when I had my very first car 5 years ago! Same vibes over there! Peugeot forums in general are quite informative.(10-04-2013, 07:19 AM)306Brad Wrote: Forgot how involved 306oc is! Also love how the answer to most problems is a large hammer haha Another "Help" Torsion Bar Thread! - 306Brad - 10-04-2013 Breaking news!! Managed to get the offending offset washer out! Came down to the dremel in the end, had to cut it out then bashed it with the slide hammer! Effort. Just bought some PlusGas off Amazon to soak the torsion bars in till ive got a weekend off to have a go! Cheers for all the replies gents
Another "Help" Torsion Bar Thread! - 306Brad - 16-04-2013 In the mean time does anyone have the part numbers for these? RE: Another "Help" Torsion Bar Thread! - puglove - 16-04-2013 check the for sale section some one is selling all off the above induvidualy . as you have to buy like packs of 10 of each from peugeot
Another "Help" Torsion Bar Thread! - 306Brad - 16-04-2013 (16-04-2013, 08:15 AM)puglove Wrote: check the for sale section some one is selling all off the above induvidualy . as you have to buy like packs of 10 of each from peugeot Can you send me a link cant seem to find it?! Cheers RE: Another "Help" Torsion Bar Thread! - puglove - 16-04-2013 you need to look further than the 1st page of sale items lolhttp://306oc.co.uk/forum/thread-11775.html RE: Another "Help" Torsion Bar Thread! - 306Brad - 16-04-2013 (16-04-2013, 11:44 AM)puglove Wrote: you need to look further than the 1st page of sale items I did ahah just not far enough.. all out of stock. Boo! |
