Dash vibration - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Dash vibration (/showthread.php?tid=1126) |
Dash vibration - Bananalad - 27-01-2012 Have a very loud dash vibration at certain revs in the dturbo.. Normally im one to say "turn the radio up it'll be graaaaaand" but this is fairly aggressive its right above the steering wheel anyone had this problem before?
Re: Dash vibration - gareth7 - 27-01-2012 Might be worth checking the fixing bolts that are under the scuttle panel...I had a similar problem a while back, nipped them up a bit and it did reduce it. Re: Dash vibration - Foxy-jim - 27-01-2012 Check your engine mounts. Re: Dash vibration - THE_Liam - 27-01-2012 It could possibly be because it's French? ![]() In all seriousness though, I'd check the engine mounts mate. Re: Dash vibration - cully - 27-01-2012 get the wheels balanced maybe a wheel weight has fallen off Re: Dash vibration - Connor - 27-01-2012 Turn the radio up Dash vibration - Matt - 27-01-2012 Connor Wrote:Turn the radio up This is what I do
Re: Dash vibration - Bananalad - 27-01-2012 Nah its not the engine mounts ill try tighten the dash up
Re: Dash vibration - Daniel306 - 27-01-2012
Re: Dash vibration - Ian - 27-01-2012 Manifold heat shield? Re: Dash vibration - sweeney1987 - 28-01-2012 never seen a manifold heat shield on a dturbo? tighten dash or balance wheels, if that dont work, sell it
