Dw8 Bosch? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Dw8 Bosch? (/showthread.php?tid=10985) |
Dw8 Bosch? - Niall - 17-02-2013 I'm stupid when it comes to dervs so bare with me! A friend has just got a car with a dw8 in with a Bosch pump. Obviously it's not the same Bosch as on the XUD but is it still alright to run on veg? RE: Dw8 Bosch? - samass - 17-02-2013 Dw8... Isn't that an hdi? RE: Dw8 Bosch? - Anton - 17-02-2013 its a nad, whack it in. RE: Dw8 Bosch? - Mattcheese31 - 17-02-2013 (17-02-2013, 11:09 AM)Anton Wrote: its a nad, whack it in. what he said^^^^^^^^^ . . . . .missing a 'bine but got the all important Boooosh . . ![]() and it is an xud, dw8 is just the engine code thingy . RE: Dw8 Bosch? - Chris - 17-02-2013 It's not a xud. It's a dw8, the replacement for the xud. Still idi but with a semi electronic pump iirc. RE: Dw8 Bosch? - Matt - 17-02-2013 I thought dw8 was nad 1.9? Like in the 306? RE: Dw8 Bosch? - Chris - 17-02-2013 Yea it is, 1.9 non turbo RE: Dw8 Bosch? - David - 17-02-2013 (17-02-2013, 12:26 PM)Chris Wrote: It's a xud. Is it though Chris
RE: Dw8 Bosch? - Mattcheese31 - 17-02-2013 The DW8 is for all intents and purposes an evolution of the XUD9 and is the only Diesel engine in the family not to feature a turbocharger or common-rail direct injection. It has a bore of 82.2 mm and a stroke of 88 mm for a displacement of 1868 cc. It is mainly used in vans such as the Citroën Berlingo and Peugeot Partner but can also be found in more affordable versions of the Peugeot 206 and 306. The DW8 was phased out in 2007 as it does not pass Euro IV emissions regulations (it is an Euro III engine[1]). RE: Dw8 Bosch? - londondan86 - 17-02-2013 (17-02-2013, 06:54 PM)Mattcheese31 Wrote: The DW8 is for all intents and purposes an evolution of the XUD9 and is the only Diesel engine in the family not to feature a turbocharger or common-rail direct injection. It has a bore of 82.2 mm and a stroke of 88 mm for a displacement of 1868 cc. It is mainly used in vans such as the Citroën Berlingo and Peugeot Partner but can also be found in more affordable versions of the Peugeot 206 and 306. The DW8 was phased out in 2007 as it does not pass Euro IV emissions regulations (it is an Euro III engine[1]). Full marks to this man, perfect answer, lol! RE: Dw8 Bosch? - Matt - 17-02-2013 Something tells me google helped
RE: Dw8 Bosch? - rickye - 17-02-2013 and it may be a non ecu pump, we worked on a 98 belingo, had a dw8, with a non ecu lucas pump on it most dw8's are semi ecu but early ones iirc arnt RE: Dw8 Bosch? - Mattcheese31 - 18-02-2013 (17-02-2013, 08:26 PM)Matt Wrote: Something tells me google helped cough . .what? . . .
