ZX TD and Xsara TD interchangeable? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: ZX TD and Xsara TD interchangeable? (/showthread.php?tid=10362) |
ZX TD and Xsara TD interchangeable? - Zippy121 - 31-01-2013 Hi all, just wondering if a Xzara TD (not HDI) gearbox is interchangeable with a ZX TD engine? Or vice versa? Thanks in advance David RE: ZX TD and Xsara TD interchangeable? - Dan! - 31-01-2013 Yep. Same box but may/may not have different ratios RE: ZX TD and Xsara TD interchangeable? - Zippy121 - 31-01-2013 Not too fussed about the ratios, been offered a seriously low mileage Xzara TD engine for my ZX Volcane TD but needed to know if my original gearbox would fit? Thanks for the info, much appreciated. RE: ZX TD and Xsara TD interchangeable? - Anton - 31-01-2013 Yes it will. RE: ZX TD and Xsara TD interchangeable? - Piggy - 31-01-2013 identical bare box/block RE: ZX TD and Xsara TD interchangeable? - Zippy121 - 31-01-2013 Thanks for all your fast replies, I was pretty sure it would be the same but didn't fancy stripping everything out only to find I needed the gearbox as well. Cheers David |
