HKS EGT wiring? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: HKS EGT wiring? (/showthread.php?tid=10217) |
HKS EGT wiring? - Jonny81191 - 27-01-2013 Does anyone have a wiring diagram for one of these? I'm a bit stumped TBH, I can only get the backlight to work, the gauge wont give a reading.. RE: HKS EGT wiring? - darrenjlobb - 27-01-2013 I have a HKS gauge, wiring is pretty simply, should be two spare wires with connectors on the end that you dont need / if you connect together should sweep the gauge to test... Ill try and get down workshop later and take a photo, dont use it anymore. RE: HKS EGT wiring? - Jonny81191 - 27-01-2013 Cheers mate that'd be great if you could. Just to check, if I connected it up and heated the thermocouple with a cigarette lighter, it should read shouldn't it? RE: HKS EGT wiring? - darrenjlobb - 27-01-2013 Nah wouldnt be near hot enough.. Put a blowtorch near the end of it / heat gun and ull start to activate it Takes few seconds for probe to warm up / react also RE: HKS EGT wiring? - strictly_perv - 27-01-2013 How much was it/where was it from? I'm looking to get one. RE: HKS EGT wiring? - darrenjlobb - 27-01-2013 I bought a stack one after that as my HKS one was always really dodgy for some reason, think it costs about 120 iirc RE: HKS EGT wiring? - Jonny81191 - 27-01-2013 (27-01-2013, 01:28 PM)darrenjlobb Wrote: Nah wouldnt be near hot enough.. That'll be it then lol, I assumed a lighter would be enough to get it to register a reading. (27-01-2013, 01:30 PM)strictly_derv Wrote: How much was it/where was it from? I'm looking to get one. I got it second hand, I want a Stack one to match my other gauges, but for some reason they're twice the price of the boost and oil temp gauges I got. Cheers Darren. I wasn't making it hot enough lol RE: HKS EGT wiring? - anto - 10-04-2013 Jonny did you ever sort the wiring on this? I have a HKS gauge as well with the following wiring colours; Yellow Grey White Red Black Any ideas? My thoughts would be; Yellow - ? Grey - ? White - ? Red - Positive Black - Negative RE: HKS EGT wiring? - anto - 12-04-2013 Yellow - illumination Red - Ignition +ve Black - Ground White/ Grey - Join together to set the warning light level. |
