Silverzx's White 205 1.9 DT XUD - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=39) +--- Thread: Silverzx's White 205 1.9 DT XUD (/showthread.php?tid=8819) |
RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - ozonehostile - 12-12-2013 Get a new light stalk, they always wear out on 205 Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - td_dan - 12-12-2013 Just follow the wires from the original cluster to underneath the glovebox (which you dont have lol) and literally unplug 2 plugs its very simple RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 12-12-2013 (12-12-2013, 11:58 AM)td_dan Wrote: Just follow the wires from the original cluster to underneath the glovebox (which you dont have lol) and literally unplug 2 plugs its very simple Really that simple? If it is I'm onto a winner winner chicken dinner time! Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - td_dan - 12-12-2013 Ye just trace the wires and plug it in i think its 2 plugs into the main board Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 18-12-2013 Had a brief glance at the wiring and didn't like what I saw! Finally fixed the speedometer by replacing the cable so can finally see how fast I'm actually going again. Still have a nice boost leak (I think) as it's running 15 psi, a random drop from 18. It sounds like it's pushing a lot of air and not going anywhere. My main beam has decided to randomly decide when it wants to work that wasn't particularly fun this evening. Think I need a stalk or possibly new HIDs as they work on sidelight (not main or full). Perhaps the cold doesn't agree with them. Also need a few other 205 bits if anyone's breaking one..
RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - Paul_13 - 18-12-2013 What bits do you need mate? RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - Tom - 18-12-2013 I need a blower motor silver boy take your stalk apart and see if you can sort it, I done it on mine when my washers were dodgy!
RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 18-12-2013 (18-12-2013, 06:15 AM)Paul_13 Wrote: What bits do you need mate? PM'd. (18-12-2013, 09:10 AM)Tom Wrote: I need a blower motor Uhhhh, how..?
RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - Tom - 18-12-2013 Take it off, 2 screws on the bottom then, take the metal clips off holding the 2 halves together and see what's on inside. RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 18-12-2013 (18-12-2013, 09:24 AM)Tom Wrote: Take it off, 2 screws on the bottom then, take the metal clips off holding the 2 halves together and see what's on inside. Probably a lot of corrosion. Shove a load of foil in there?
RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - Tom - 18-12-2013 Mine was just covered in dirty grease, cleaned it all out and stuck some fresh in there and its fine now. RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 18-12-2013 (18-12-2013, 09:48 AM)Tom Wrote: Mine was just covered in dirty grease, cleaned it all out and stuck some fresh in there and its fine now. Grease you say.. White grease any good? RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - Tom - 18-12-2013 Slippery grease mate I just use multi purpose grease for everything lol I'm sure Vaseline would work fine as well.
RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - ozonehostile - 21-12-2013 don't worry trent il be over one day soon. it will be bosched! RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 29-12-2013 (21-12-2013, 09:10 PM)ozonehostile Wrote: don't worry trent il be over one day soon. it will be bosched! Thanks dude! Alternator died, drove home with no electrics under the drawing night sky. Sub went first, then radio, then lights, then indicators. A job for tomorrow. RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - Paul_13 - 29-12-2013 Check the pumps not leaking, alternators don't like oil and that. Don't want you killing another one. RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 29-12-2013 (29-12-2013, 09:31 PM)Paul_13 Wrote: Check the pumps not leaking, alternators don't like oil and that. Don't want you killing another one. Just replied to you over on 205gti. Hopefully it's getting bosch put on soon so shouldn't be a problem either way. When it was fitted I accidentally put the + and - on the wrong way and it smoked a bit so think it's done well to last this long to be honest! RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - ozonehostile - 29-12-2013 Haha, at least you know what killed it though RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 07-01-2014 11mm's on as of Sunday morning, much thanks to Darren for the pump and Zakk for the much needed assistance fitting it! A massive improvement over the lucas. Lucas before: ![]() Bosch after: ![]() At the Exeter meet: ![]()
RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - Carlos182 - 07-01-2014 How the fcuk did you manage that?! RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - mr_fish - 07-01-2014 ahh bugger, doesn't look like that tickled :S RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - ozonehostile - 07-01-2014 Was a good refresher fitting the bosch, it's been a while haha. Had a bit of an issue with the tensioner on the cambelt being a bit reluctant to move up or down and the issues with the oil breather hose on the rocker cover. Apart from that it was a nice job :-) Oh and it ran like shit on first start, moment of inspiration, advanced the pump a few degrees and instantly ran perfectly haha So gay about hitting the front, especially after all the careful hammerite application the night before :-P Only picture I took
Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 07-01-2014 It goes well at 25PSI on 11mm & TD04! RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - td_dan - 07-01-2014 iv got a white gti front valance mate but would need collecting from birmingham RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 07-01-2014 (07-01-2014, 10:04 PM)td_dan Wrote: iv got a white gti front valance mate but would need collecting from birmingham Thanks dude, PM'd you as you know! On another note I put brand new Bosch Duraterms in this bad boy when we fitted the 11mm and it hasn't cured my smokey start up issue. I'm a bit stumped why it still starts rough as bugger! RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - strictly_perv - 07-01-2014 I've got a genuine white Dturbo valance sat in the garage along with matching rear if your interested RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 09-01-2014 So tempted to break the damn thing. Anyway.... RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - mr_fish - 09-01-2014 that wing! you sure you couldn't of hammered it in a bit?? RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - silverzx - 09-01-2014 (09-01-2014, 04:56 PM)mr_fish Wrote: that wing! you sure you couldn't of hammered it in a bit?? Don't see the point, it'll only crease in the opposite way and it's better poking out then in if you ask me. Had a quick look at what it could potentially be worth and have a few bits... As a rough idea to what I could recoup from the car and my XUD stock pile: ARP XUD Head Studs £200 GT2052V £80 K14 Bolt On £40 TD04L Bolt On £150 306 FMIC Kit Bolt On £150 Stack EGT Gauge, Probe & Adapter £40 Stack 35 PSI Boost Gauge £30 11mm Rebuilt Lobb Pump, lines, injectors £150 Aftermarket backbox £25 2.5" steel bends, straight & various bits £50 205 STDT Clocks & Loom £40 XUD Cambelt Kit £30 Bosch Duraterm glow plugs £15 9mm Bosch Pump, lines, injectors £80 Non-EGR inlet x 2 £20 each 7 x 205 GTi Speedlines £150 205 STDT exhaust £15 XUD engine x 2 £50 each Scrap value for 205 & 306 shells £80 each and various other random bits. Could probably get a grand back if I tried and start over or just drive my Datsun. Someone find me a wing, bumper and headlight in their local scrappys pretty please!! RE: Silverzx's White 205 1.9 DT XUD - GT2052V, 11mm & Much More! - Paul_13 - 09-01-2014 I'll have clocks and loom, td04 and pump if you break! Oh and boost gauge My mate will most likely have the head studs Ryans got a GTi shell on his drive he needs rid of by the way |
