Is this illegal? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Is this illegal? (/showthread.php?tid=24725) |
RE: Is this illegal? - Niall - 21-06-2014 ![]() Right that is a 306 balljoint. The bit with the 3 holes sits inside the end of the wishbone. You want to measure from one of them bolt holes to the ball joint pin its self. I bet you will find that the one on the side your having troubles with is shorter than the other side. If so, replace the ball joint (only about £15 from ECP) with one for a PAS car. RE: Is this illegal? - Nathan1305 - 21-06-2014 (21-06-2014, 12:58 PM)Niall Wrote: Awesome thanks Niall so I wanna measure from the centre of the hole to the centre of the ball joint pin like this?[attachment=17003] RE: Is this illegal? - Niall - 21-06-2014 yeah can do. you will have to remove the ball joint from the hub to dp that so you could just measure both from one of the bolts to a point on the back of the hub RE: Is this illegal? - Nathan1305 - 21-06-2014 (21-06-2014, 01:41 PM)Niall Wrote: yeah can do. you will have to remove the ball joint from the hub to dp that so you could just measure both from one of the bolts to a point on the back of the hub Yeah that way will be easier so measure from the bolt to the hub |
