Broken gti6, update/help? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Broken gti6, update/help? (/showthread.php?tid=16998) |
RE: Broken gti6, update/help? - Chris_90 - 08-09-2013 Thanks for the heads up c2k, but I can see the inlet valves are bent now the inlet is off, will find out the true extent of the damage when I get the head off. Any no what could have caused it to slip on the front cam? What's the best way to remove exhaust manifold? RE: Broken gti6, update/help? - C2K - 08-09-2013 Exhaust manifold can be done from above but easiest from below, it's a bitch . Perhaps Cambelt Snapped and was poorly timed. Where did you find the pullies? RE: Broken gti6, update/help? - Chris_90 - 08-09-2013 (08-09-2013, 08:06 PM)C2K Wrote: Exhaust manifold can be done from above but easiest from below, it's a bitch . Cambelt hadn't snapped was ok, bottom end locked off and rear cam locked off fine front one was out by about 80-90degrees. The woman had the car for 4 years with out issue she said this is first problem she had apart from cat for mot. Not looking forward to the exhaust manifold then
RE: Broken gti6, update/help? - C2K - 09-09-2013 I would have thought 90 degrees beyond the possibility of a pulley slot, it's maybe 30 degrees arc of rotation I recall. to have more would indicate that it was poorly timed - perhaps someone had a go at belt before you after cambelt snappage was what I meant.
