Rpm vs Speed, what do you do?? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Rpm vs Speed, what do you do?? (/showthread.php?tid=22642) Pages:
1
2
RE: Rpm vs Speed, what do you do?? - randomcaller - 30-03-2014 I'm running a be3 standard 205 na diesel box on mine and if memory serves me correct is has the gearbox code on the near side of the box where you fill the oil from the side of the gearbox (first box I've worked on where you fill the oil from the side :z ) I'll have to check but I think a quick look under the passenger wheel arch it's visable but it might only say the series like be3 so don't 100% believe me on this lol RE: Rpm vs Speed, what do you do?? - Poodle - 30-03-2014 Retarded thread is retarded. ![]() EDIT: Tbh sounds like you've got a standard 205 dt box on it, mine does ~60 @3k rpm, but that said it can't do because you're sure it's an xud9te box.
RE: Rpm vs Speed, what do you do?? - Anton - 30-03-2014 Lol... RE: Rpm vs Speed, what do you do?? - Tom - 30-03-2014 ![]() What now? Rpm vs Speed, what do you do?? - silverzx - 30-03-2014 Hdi box now. RE: Rpm vs Speed, what do you do?? - Tom - 30-03-2014 Id like to know what this is on there now. As far as my knowledge goes that cant be a 205 box because they are BE1? RE: Rpm vs Speed, what do you do?? - Poodle - 31-03-2014 Two minutes on google says the dts and some GTis came with the be3. RE: Rpm vs Speed, what do you do?? - Dave - 31-03-2014 Try sitting at 70mph with a 6 box on a derv :p that really does your nut in... RE: Rpm vs Speed, what do you do?? - Tom - 31-03-2014 I sit at 3.5k at 70, well i dont because it sucks balls i just cruise at 50 instead... |
