FMIC HELP! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: FMIC HELP! (/showthread.php?tid=20452) Pages:
1
2
RE: FMIC HELP! - Jenkosowls - 19-01-2014 Need thicker wire? I'v seen 0.8mm wire perfectly weld 10/12mm plate fine I'd look into penetration and wire speed before hand RE: FMIC HELP! - Wor Jimmy - 19-01-2014 (19-01-2014, 12:18 AM)Jenkosowls Wrote: Need thicker wire? that would be the case with mig Its tig bud
RE: FMIC HELP! - Rippthrough - 19-01-2014 Just do what every other TIG welder does in a pinch and twist two wires together in the drill... RE: FMIC HELP! - Jenkosowls - 19-01-2014 Or feed it longer RE: FMIC HELP! - Wor Jimmy - 19-01-2014 (19-01-2014, 01:11 AM)Rippthrough Wrote: Just do what every other TIG welder does in a pinch and twist two wires together in the drill... True!.. long day
RE: FMIC HELP! - Dean - 23-01-2014 I still need to drop the grinder off... uhhhhmmm well i'm coming over Saturday.. so we can do test fittings, and get these bad boys made up. And MAYBE get the turbo off, or at least the elbow im craving more boost unfortunately.
RE: FMIC HELP! - Wor Jimmy - 24-01-2014 (23-01-2014, 11:12 PM)Dean Wrote: I still need to drop the grinder off... uhhhhmmm well i'm coming over Saturday.. so we can do test fittings, and get these bad boys made up. You can fit the F*ckers.. after my "hole in the hand" situation. FMIC adapters on hold untill i can hold items in my bloody hand again. ![]() (Joys of accidents in engineering) RE: FMIC HELP! - Wor Jimmy - 26-01-2014 Ok one is deans car now. testing it for a few days! nothing else i can do until my hand is fixed |
