Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Stereo interference...nearly there...just need last bit of HELP!!!!!!! (/showthread.php?tid=18489) Pages:
1
2
RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Dean - 18-11-2013 (18-11-2013, 07:19 PM)Piggy Wrote: OK. Did you try moving the RCA + the other wire, cant remembre the name, not the power one though.. lol. But yeah move them to the other side of the car away from the power wire? RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - WiNgNuTz - 18-11-2013 RCA and Remote one side of the car, power from the battery the other. RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 18-11-2013 did that ages ago... no difference battery in boot...so power cable goes direct to amp anyhow but rcas now go down side of car RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Dean - 18-11-2013 (18-11-2013, 10:47 PM)Piggy Wrote: did that ages ago...Where abouts is the earth for the battery? RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 19-11-2013 two earths. both going direct to chassis...within 12inches of the battery RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - jamie23 - 20-11-2013 i'd get/borrow another head unit to try apart from two you have then you know for sure if head units knackered tbh seems like your going through alot of trouble when it sounds like its stereo's phono plugs are shot RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 22-11-2013 seems so. also seems odd for a top end pioneer unit which was 300ish new and has been boxed since new till i bought it. im bit gutted Stereo interference...nearly there...just need last bit of HELP!!!!!!! - devils_fuel - 23-11-2013 (22-11-2013, 10:10 AM)Piggy Wrote: seems so. Are you sure the stereo is as new and not fecked around with, it does sound dodgy for a new pioneer to feck up RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - AssMonkey13 - 23-11-2013 does the pitch noise change when you rev the car ? RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 24-11-2013 (23-11-2013, 04:48 PM)devils_fuel Wrote:(22-11-2013, 10:10 AM)Piggy Wrote: seems so. theres a onbaord fuse on the phono earth side...but I cant get to it, its part of the circuit board, apparantly if 12v is sent wrong way, tripped somehow down wrong phono wire that little fuse blows. Seems to exhibit those symptoms. New HU seems fiine, still the TINYIEST hint of a "pip" when something electrical is turned on/off with vol on 0 and you listen really close. But I can live with that (23-11-2013, 04:51 PM)AssMonkey13 Wrote: does the pitch noise change when you rev the car ? see post #3 Stereo interference...nearly there...just need last bit of HELP!!!!!!! - devils_fuel - 24-11-2013 (24-11-2013, 08:41 AM)Piggy Wrote: theres a onboard fuse on the phono earth side...but I cant get to it Had this on a kenwood mask, removed the cover and used tweezers to change it RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 24-11-2013 its a circuit board track more than a fuse. but it works as a fuse Stereo interference...nearly there...just need last bit of HELP!!!!!!! - devils_fuel - 24-11-2013 That's a sh*tter mate
RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 24-11-2013 yup. oh well. looks like me mums getting a nice pioneer HU Stereo interference...nearly there...just need last bit of HELP!!!!!!! - devils_fuel - 24-11-2013 There you go, an Xmas pressie sorted including fitting
RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 29-11-2013 ahhhhhhhhhhhhhhhhhh after 10days or so of trouble free amped music... started the car after stopping at tesco and 'mnnnnnnnnnnn' buzzy sound is back, in tune with engine revs! what the hell!!!?? really annoyed RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 29-11-2013 anyone know how to test a alternator suppressor?? I wonder...my voltage had rissen to around 15.2vs generally...but in tandem with the buzzing coming back, the voltage has dropped back down to 14/14.2vs and Im thinking maybe the suppressor has blown?! Stereo interference...nearly there...just need last bit of HELP!!!!!!! - devils_fuel - 29-11-2013 Can the suppressor you bought handle 15amps or can you find one? RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 29-11-2013 Duno what amp rating it had...but was for high capacity diesel alternators. Felt a bit poor quality mind Stereo interference...nearly there...just need last bit of HELP!!!!!!! - devils_fuel - 30-11-2013 Sounds like it should have been man-enough but then again eBay... RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 30-11-2013 its 3.3 micro farod. which is actually quite high. Ordered a new one but highest could now find was a 1mf Stereo interference...nearly there...just need last bit of HELP!!!!!!! - devils_fuel - 30-11-2013 Fingers crossed mate ![]() Just a thought...have a you swapped the alternator just in case there's an issue with your current one?? RE: Stereo interference...nearly there...just need last bit of HELP!!!!!!! - Piggy - 30-11-2013 not gota spare
