FAO Ginge191 - pipes - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: FAO Ginge191 - pipes (/showthread.php?tid=1154) Pages:
1
2
Re: FAO Ginge191 - pipes - Chris - 29-01-2012 I'll see if its long enough phill, the 406 pipe I've got keeps blowing off and hangs stupidly low. Re: FAO Ginge191 - pipes - 4WayDiablo - 29-01-2012 Ok np. Ill send you one of the other 2. Still sealed in their bubble wrap lol Re: FAO Ginge191 - pipes - ginge191 - 29-01-2012 Phil - a company can make it up for me with: 1 x 90deg silicone 57-51 reducer 1 x straight alloy coupler 1 x 90deg silicone 51mm bend you reckon there would be enough room for this? Re: FAO Ginge191 - pipes - Connor - 29-01-2012 4WayDiablo Wrote:Chris Wrote:Phill, is that bend in the last pic a 90* and a 2.25" Might be the photo... but thats a funny looking 90 degrees... Re: FAO Ginge191 - pipes - ginge191 - 29-01-2012 i think its 92*
Re: FAO Ginge191 - pipes - ginge191 - 30-01-2012 ginge191 Wrote:Phil - a company can make it up for me with: Phillip? Re: FAO Ginge191 - pipes - 4WayDiablo - 30-01-2012 ginge191 Wrote:didnt see that there lmaoginge191 Wrote:Phil - a company can make it up for me with: my pipes are 57mm? am i missing something? Re: FAO Ginge191 - pipes - ginge191 - 30-01-2012 im assuming that the 57-51mm is irrelevant which way it goes round?? Re: FAO Ginge191 - pipes - 4WayDiablo - 30-01-2012 true but why is there another 51mm 90 bend? surely that should be a 57mm no? Re: FAO Ginge191 - pipes - ginge191 - 30-01-2012 Im assuming the joiner pipe is 51mm? i shall enquire Re: FAO Ginge191 - pipes - 4WayDiablo - 30-01-2012 joiner pipe? so confused? so your going 51mm 90 / 51- 57mm 90 to make the u bend to send it gearboxwards? Re: FAO Ginge191 - pipes - ginge191 - 30-01-2012 4WayDiablo Wrote:joiner pipe? so confused? so your going yes, and a joiner pipe to join the two 90* together... as 90 + 90 = 180 :geek: this is the only viable way to create a U bend from turbo at 51mm to piping at 57mm
Re: FAO Ginge191 - pipes - 4WayDiablo - 30-01-2012 ginge191 Wrote:A 51mm u bend then 51 - 57 adapter then straight pipe?4WayDiablo Wrote:joiner pipe? so confused? so your going Re: FAO Ginge191 - pipes - ginge191 - 30-01-2012 oui! turbo -> 51mm 90* -> joiner pipe -> 51mm - 57mm 90* -> straight pipe.... Re: FAO Ginge191 - pipes - 4WayDiablo - 30-01-2012 Or just get 1 x 180 bend 51mm then get a 51 - 57 adapter is what i was trying to say Re: FAO Ginge191 - pipes - ginge191 - 30-01-2012 4WayDiablo Wrote:Or just get 1 x 180 bend 51mm then get a 51 - 57 adapter is what i was trying to say ohhhhhhhhhhhh i get you! that could make more sense i suppose, saves faffing around, id still need a joined pipe as i cant just pop two pieces of silicone together, right? unless you have some odd 51mm pipe? edit: 180* 51mm -> joiner pipe -> 51mm - 57mm http://www.ebay.co.uk/itm/Black-Silicon ... 1750wt_854 http://www.ebay.co.uk/itm/Alloy-hose-jo ... 1e603e356e http://www.ebay.co.uk/itm/SILICONE-NOME ... 3368b73e06 Re: FAO Ginge191 - pipes - 4WayDiablo - 30-01-2012 They do solid pipe ones. Stainless 51 to 57. Then i have some 57 straight silicon perfect to join. The third pic on the first post. The red pieces Re: FAO Ginge191 - pipes - ginge191 - 30-01-2012 http://www.ebay.co.uk/itm/51mm-57mm-ALL ... 4aa785c660 BOOM! i'll crack on and order now! ![]() OH and i may need a 90* silicone piece to get round the engine?? Re: FAO Ginge191 - pipes - 4WayDiablo - 30-01-2012 You said you would get that lol ive got stainless 90's we can cut down if you want...? Re: FAO Ginge191 - pipes - ginge191 - 30-01-2012 4WayDiablo Wrote:You said you would get that lol ive got stainless 90's we can cut down if you want...? yeh i'm just ordering now so im re-affirming to myself, you can keep that intact mate ![]() I'll buy the 51mm ubend, metal adapter and 90degree silicone - should be plenty full! |
