As title really anyone in the Midlands area known to give good stage 1 for a hdi?
Buy yourself a KWP2000+ for £20 and buy a map off someone on here, then do it yourself. Save £££ and have the luxury of being able to redo your car whenever you please.
the main reason being my history with technology would mean i'd probably turn the engine into a bread roll.
Ive got a kwp in chesterfield if that helps?
Mr whippet is only in Leeds. Took me about a hour from j26 m1.
45 minutes on way back
You buy a file and I can put it you on!
I went to pro steve coming from birmingham took me just over an hr
(11-01-2013, 03:18 PM)silverzx Wrote: [ -> ]Buy yourself a KWP2000+ for £20 and buy a map off someone on here, then do it yourself. Save £££ and have the luxury of being able to redo your car whenever you please.
Yes you can but be very carefull as i bricked an ecu with a Galletto, maybe the kp's diffirent or better but i wont do it again
Done it loads of times and never bricked an ECU, just got to follow the instructions. The key is having a decent laptop and not touching anything while it's writing.
I know and i did that.....and didnt tiuch anything but stopped half way through the write and fkd it
Cheers for the responses folks, ive been having a chat with Mr Whippet about maps.
(21-01-2013, 01:12 PM)stu9 Wrote: [ -> ] (11-01-2013, 03:18 PM)silverzx Wrote: [ -> ]Buy yourself a KWP2000+ for £20 and buy a map off someone on here, then do it yourself. Save £££ and have the luxury of being able to redo your car whenever you please.
I've done 5 or 6 remaps now on different cars with a Galletto and a crap old Acer laptop, really is just bad luck if you brick an ECU.
If you still need a remap, I can make one for you.
Ask DumDum or Pipps how my maps are, they both run them. (and probably a lot of other members as well)
How much do you charge for a stage 1? And what power do you state?
Mine's running a map by tb and I'd highly recommend his services........
(01-02-2013, 02:48 PM)Kezzieboy Wrote: [ -> ]How much do you charge for a stage 1? And what power do you state?
Stage 1 is up to 130BHp tops. 130 requires every single bit in the engine is perfect, so expect 125bhp. Torque is 280NM.
Stage2 is up to 160BHp 360Nm
Stage2+ is 160BHp 390Nm
...Beyond that, it depends on the hardware used, but up to 210Bhp and 450nm relatively easy. More than this and it gets expensive.
(03-02-2013, 08:35 PM)tb205gti Wrote: [ -> ] (01-02-2013, 02:48 PM)Kezzieboy Wrote: [ -> ]How much do you charge for a stage 1? And what power do you state?
Tb how do I get in contact with you mate?
Im gonna be requiring a stage 2 in the very near future and your pm has been disabled
My PM should work by now. Apparently you need at least 10 posts before the PM system is activated
(04-02-2013, 10:45 PM)Kezzieboy Wrote: [ -> ]How many monies dude?
Well it depends on what you want done.
anyone in the suffolk area good at mapping or able to upload a map for me?
I can do a stg1 file for £75, or stg2 file for £100, along with support (ie, if you brick the ECU etc)
Thanks
Dave
