Are they recommended as eurocar parts don't stock Gates timing belt
They make some of the best bearings you can get also do a lot of commercial type belt products
I wouldn't have an issue fitting it
i used to work for them so i have every single bearing they make for a 306 in my shed! hehe
and yes best quality stuff out there.
Need find water pump as kit don't contain one
Buy a gates kit off the bay? 98delivered
Best bearing you can get.
Although my Cambelt was done with the bearing and one wasnt central while rotating it would rotate at an angle and there for after a few k miles the Cambelt made a bid for freedom and shredded itself mangled some valves while it was at it :/
that wasnt a skf bearing matt. all skf bearings are marked.
It was. You even pointed it out to me that it was skf....
Still have it somewhere
