Some may know I had a slammed PH2 blaze D Turbo but it got wrote off.
So a few weeks ago I bought this.
£380 10 month mot 5 month tax on 123k body work is pretty mint for the age
Required a downpipe so I got a brand new one fitted
And the door looms had broken whilst the window was down so the previous owner ripped the door card off and cut the cables
I fixed the loom and fitted the motor out if my blaze.
I got it insured this week and Wednesday started ripping things off that are no longer wanted
This was replaced by this
In the process I heard a hissing noise, I had broken the air con rad yes my £380 ph1 d turbo had pressurised air con! So need a new air con ra if anyone has one?
Then out came this
And this took its place
Nice TD04
After that a nice cambelt change and this went on
Then changed the top engine mount but didn't go to plan
So got the welder out and welded this in and fitted a new mount
All ready and done Friday night ready for the rollers Saturday.
Video from the rollers
Rollers
I was hoping for around 150-160 and I'd be happy
Graph
176.6 Bhp and 247 lb ft of torque I was really happy for a 9mm with a ground lda and gov mod and top mount
It's really clean on boost no smoke so I think bit more fuel and I could crack 180bhp
Comments and Criticism
Thanks
Dont know what you mean
be quite different soon.
looks clean you dont hang about do you good luck with it
Thanks mate
few changes to come yet
it's a beast Danny lol . . . .just needs a tidy inside coz it's like a bloody turbo charged bin mate .
could have cracked the 180 mark danny with some slight tweaks after all we hadnt had much time to tweak it
Danny i meant to ask, have you got a quick shift fitted or a cut down stick? you were making those changes pretty fast when you took me for a spin . .
Good result there mate! Good work!
(14-10-2012, 05:02 PM)Mattcheese31 Wrote: [ -> ]Danny i meant to ask, have you got a quick shift fitted or a cut down stick? you were making those changes pretty fast when you took me for a spin . .
haha he just uses his left arm allot......
You said you wouldn't tell anyone!
No i haven't pal clutch down bang it in gear bang clutch up job done, been meaning to get a griffiths quick shift may buy one just reminded me
Very impressed with that myself!
(14-10-2012, 08:00 PM)Tom Wrote: [ -> ]No front mount?
front mounts are so last year . .
Now I see where that fog light is coming from
Great to see the hard work this week has paid off.
Impressive result! :-) nice one!
How does the clutch hold out
Top mount ftw looking into other alternatives other than fmic
Cheers pal, clutch holds fine and it gets drove like a big boosted derv should every day expected it to slip but its ok for now.
What psi does that run? Thats a good result
im suprised you can get that much still on a tmic! love it swap for my hdi?? ;-)
Haha I'm surprised to he has got that much from such a quick swop and tune. I must have got the last minute tweaking spot on. Just goes to show a top mount is up to the job. Makes it an uber stealth too! Ha a couple if talks with Danny and advised that water meth injection would be a good route next and simpler than fmic.
was good meeting you mate. your car is a epic sleeper lol. the graph is similar to mine apart mine didnt pull as good
Cheers lads
Not a fan of hdi's I'm happy with this anyway for now.
It's running around 28 psi de wastegated
I'm liking the stealthy side of it but it has no stance need my coilies and wheels on asap
Doesnt the charge get hot as? Well something bloody hot!
Edit: Seeing this amount of power on a top mount has got me a mouse click away from buying a td04
Not sure about simpler or cheaper than a front mount.
But it is a good way to go.
Good results through.
Don't think I know anyone with meths. Fancy something different everyone seems to just have big coolers hanging out the bumper which I'm not a fan of
Still pulls ok even after a hard drive.
The only thing that can fail on a FMIC setup is a pipe blowing, and if you use proper silicon, and beaded pipes this will NEVER happen, I promise..
Water meths has very high maintenance...using water alone is pretty useless, its the meths that makes it epicly effective, this costs money, and it will drink the stuff...trust me...so already more expensive day to day...you have wiring to fail, plumbing to fail, nozzles to fail, pump to fail, etcetc, so much more likely to cause problems, and its more expensive...theres nothing wrong with water meths injection, hell no, i run it, and its fantastic...BUT theres alot of people who seem to think its the better option / easier option...which really isnt the case IMO...
Also on the topic of fmic's....its worth noting, you can make ANY ammount of power on a dyno on a TMIC...the TMIC makes little difference in single pulls on a dyno, hell you could probs do 300hp on a hx35 on a tmic on a dyno....but driving it fast road / track would be hopeless...The problem with the TMIC is is simply dosnt cool down once its hot...on a dyno its fine, because its cool and during one pull dosnt get that hot...during normal driving however, it gets raping hot in the first 5 minutes, and is then totally useless from then on...I wouldnt say FMIC is last year at all / is pretty much essential in ANY tuned diesel setup....again IMO (I find myself having to use "IMO" constantly these days to avoid people starting heated debates all the stupid time!)
(15-10-2012, 07:02 PM)darrenjlobb Wrote: [ -> ]The only thing that can fail on a FMIC setup is a pipe blowing, and if you use proper silicon, and beaded pipes this will NEVER happen, I promise..
i'm only stirring Darren tbqh . .
. . . .point taken about charge temps, at the RR day i was on about to a few people about how much harder the car pulls on a cold evening it's stupid! . . . . . . .i suppose it depends on how you drive, if you rag it plenty you need extra cooling whichever route you go . .
You don't need to have a fmic hanging out the front bumper, even a smallish fmic will work better than a tmic.
Just rip out the fans, wiring up a few slim fans and pipe up your front mount behind the bumper.
I'm only looking Into water meths, no idea where I would get the meths from tbh! Still researching about it tbh it just took interest to me as its a different route to a fmic.
Thanks for the input as saying still researching about it.
I used to get epic heat soak on a T2 running 12psi (lol) so fmic's (or equal cooling measures) are essential for cars running lots of fuel and boost!
