Full Version: Knocking from rear
Got an annoying knock coming from the rear.. sounds like a drop link would, but at the back. It is even worse if you are braking.
Checked over:
- Beam mounts
- Shock bushes
- Beam bearings
- Exhaust to see if it hits anything
- I don't have a spare wheel cage so that isnt it
- Rear caliper bolts are correctly torqued
- Disc protector correctly tightened
Pissing me off now!
how have you check the beam mounts? some times they look ok but there are acutally shagged! i would put my money on it being them.
It's f*cked.
Scrap it.
/dumdum
Knackered shock?
I would place a bet on one of the four beam mounts. As said the wear cant always be seen on the big main mounts
drop axel off and check Smile
I heard solid rear beam mounts knock anyway... Didn't you fit those as part of the group buy, or am I imagining it?!!!
