Is it possible to have a fmic and use my standard inlet thanks in advance
Yeah you can, but you will need an adaptor for it so you can clamp the pipe
As Connor says, you can with an adaptor, jase19 (I think) was the guys user name that used to make them, can post you a pic of mine up if you like?
Bare with me, shall go and take a pic now and move from my phone to an actual computer lol
Wow marks being helpful!
I'm always on eBay aswell can't believe I missed this
thats the same as mine, and what do you mean Connor...................cheeky shite
Pics of mine installed, it wants painting again but meh, the flash makes it look worse than it actually is TBH...............
Edit:- going off the user name on ebay selling that I would say its jase I mentioned earlier as its exactly the same as mine........
I like it mate thanks for that
its by no means the best flowing solution but it is easy and saves pissing around with manifolds and making a take off for the LDA compensator on the pump (which the xantia mani doesn't have) as the 306 TD one comes off the top mount which won't be there anymore
mine has never been a problem and its been on there a while now
All you need to do to a xantia mani is just drill and tap a bleed nipple like the HDi boys do on the inlet elbow
Connor Wrote:All you need to do to a xantia mani is just drill and tap a bleed nipple like the HDi boys do on the inlet elbow
I know, but its extra faffing around and i'm all for avoiding that
Hardly... but i cba to do it on mine to connect the boost gauge
Connor Wrote:Hardly... but i cba to do it on mine to connect the boost gauge
My boost guage is joined into the boost comp hose with a tee just after the adaptor, can see it in the pics
I know, just saying I cba to faff around with mine
mark_airey Wrote:Connor Wrote:Hardly... but i cba to do it on mine to connect the boost gauge
Can you get a pic of where you put it as my next thread was about where to put the boost pipe hose please
Its what the little thing on the adaptor, next to the big hole, is for
Yeah it is connor
what for a gauge you mean? put the tee in the pipe that goes from the front of the top mount to the fuel pump and then run it into the cabin, mine is drilled through behind the battery tray which comes out behind the glove box in the cabin up behind the blower motor. just make sure you seal around it with silicone afterwards to stop it moving in the hole and the metal cutting into the hose.
That's it mate just wanted to no how/where to put the pipe for the boost gauge
Where can I buy this?
Sent from my HD7 T9292 using Board Express
declantg Wrote:Where can I buy this?
*facepalm* read the thread.............
sent from my HP laptop using Google Chromium
Well I fail
I can't seem to upload a photo of the pipe but is it the small one that goes onto the tmic
Mart Wrote:I can't seem to upload a photo of the pipe but is it the small one that goes onto the tmic
It's maybe 15-20mm across right in the middle at the front coming out the bottom and leading to the pump, its the only thing connected to the intercooler other than the manifold and feed from the turbo, lol, you can't go wrong.
Just cut it and install your tee piece with some jubilee clips
Will go take a pic of mine, bear in mind its dark
Ok thanks mate I'll have a look tomoz
Just uploading to photobucket for you
Here you go mate, it the pipe square in the middle that has been Tee'd into
