I'm going to be swapping my dturbo arb for a gti one soon,so I need to get the gti bushes. Pretty sure this is all I need for the swap?
Can anyone recommend any particular ones? I can't find any on the net apart from the cheap non branded eBay ones. If there aren't any good uprated ones about I will most likely get them straight from Peugeot.
Thanks, Ben
yeah thats all you need. go to ecp and ask for ones off a gti. Tbh there really isnt much of a difference between them!
Cool ill do that then, ta.
You might as well change the drop links while you're at it too.....
Yeah I'm going to try and change a lot of the suspension all at the same time. Anyone know the best place to get the meyle HD wishbones? And any suggestions for other good suspension parts I may want to change?
I'd probably look into getting some adjustable top mounts aswel, camber/castor adjustment etc
Yeah I thought about those but I think they might be a bit much atm. Depends how much they are I'll have a look around. I mostly want to get all bushes ect changed so that there all done then top mounts and struts will come afterwards
Not Long done this on my DT, MASSIVE improvment well recomended, BUT....................... because theres always a but, inlist the help of a friend to wiggle it out and back in, For such a simple job its a PITA on your own
Just the thread I was looking for, sorry to jump in but, does anyone know what size the bushes are on a 2000 gti6? The bloke at the motor factors says there is a choice from 17mm, 18mm, 19mm and 21mm? Cheers chaps
(17-09-2012, 07:20 PM)Claus1990 Wrote: [ -> ]Just the thread I was looking for, sorry to jump in but, does anyone know what size the bushes are on a 2000 gti6? The bloke at the motor factors says there is a choice from 17mm, 18mm, 19mm and 21mm? Cheers chaps
well the gti6 antiroll bar is 21mm . . . .sooooo 21mm i am guessing . .
(17-09-2012, 07:21 PM)Mattcheese31 Wrote: [ -> ] (17-09-2012, 07:20 PM)Claus1990 Wrote: [ -> ]Just the thread I was looking for, sorry to jump in but, does anyone know what size the bushes are on a 2000 gti6? The bloke at the motor factors says there is a choice from 17mm, 18mm, 19mm and 21mm? Cheers chaps
Ha cheers bud much appritiated, I shall purchase tomorrow
Another thing about this, a gti is the best spec handling peugeot put out in the 306,so the bigger the ARB the better, soooooooooo out of the 3 this would mean 21mm right?
This is how i worked it out any way
lol
(17-09-2012, 07:55 PM)puglove Wrote: [ -> ] (17-09-2012, 07:20 PM)Claus1990 Wrote: [ -> ]Just the thread I was looking for, sorry to jump in but, does anyone know what size the bushes are on a 2000 gti6? The bloke at the motor factors says there is a choice from 17mm, 18mm, 19mm and 21mm? Cheers chaps
This is how i worked it out any way lol
yessssss . . . except there are 4 options there . . . . :p
Yea that's seems pretty logical to be fair ha, just seemed strange that the bloke in the the motor factors couldn't get the info. I also had a look on eurocarparts and they give different sizes to choose from using my reg number
Puglove - I hope its as good a difference as you say, and I'll be changing it with the engine out so I'm assuming it'l be incredibly easy!
i've got one waiting to go on soon too, any tips for fitting? . . .take it you have to drop the subframe off . .
Just drop the back down and leave it on the front bolts (just slacken them off), you can get them in and out like that.
(18-09-2012, 12:03 PM)Rippthrough Wrote: [ -> ]Just drop the back down and leave it on the front bolts (just slacken them off), you can get them in and out like that.
cheers for the info, good man . . .
Or, put the angle grinder through one side, take it out in two halves, put it in the bin, and buy some stiffer springs.
(18-09-2012, 01:29 PM)Rippthrough Wrote: [ -> ]Or, put the angle grinder through one side, take it out in two halves, put it in the bin, and buy some stiffer springs.
you know some people might actually take you seriously? . . .
Ben.
Yes mate massive improvment. Iv also done. Gti front & rear shocks, aswell as gti front & rear ARB's and im telling you it was worth every bit of effort and time. If you are taking the lump out it will be a peice of pie. As you will be able to drop the sub framr to the floor and do it.
(18-09-2012, 03:16 PM)puglove Wrote: [ -> ]Ben.
I've got a Gti rear beam, and I have bought some Gti front shocks for the front, but that was over 5 weeks ago and I still don't have them so trying to get my money back! I'm sure I'll manage to get something soon. Yeah I'm hoping it'll be easy as pie, I've had the ARB months but thought I'd wait til the engines out to save the hassle!
Yeah id wait till the engine is out, will be much easier. but would prob be easier to do shocks at the same time to if you can get some
