03-09-2012, 06:32 PM
Pair of Bosch calipers (including carriers) removed from a 2000 (X) Peugeot 306 1.8 16v XS.
Perfect working order, only removed as the brakes were upgraded to GTi-6 spec, so I fitted GTi calipers and master cylinder in order to use the bigger disc size.
These do not come with discs or pads. The correct size discs for these calipers is 266mm.
They will fit all 1.8 16v petrol 306s (Meridian, XS etc) and XSi 2.0 petrol 306s which have the later 266mm discs fitted (earlier models had 247mm).
These are also a good upgrade for anybody with an early XSi or any year 1.9TD 306 which both have 247mm discs. These calipers come with the carriers so will fit either of these models no problem, you will just need to buy the bigger 266mm discs and correct pads!
Collection from Portsmouth, postage also available but will be quite expensive as they weigh a fair bit!
£30 collected for the pair, or £45 posted.
Cheers
Ash
Cheers
Ash
