Awsome lil project dude. Wots the blower like on the temp engine rofl
Abit too much lag for me personally tbh
P
Hahaha win
Should be good when your done mate, that Sedan looked pretty clean when I saw it! Give me a shout if you need a hand, I owe you a beer for that rad
Nice to see another Sedan on the forum.
Thanks always loved sedans. Especially lowered. I was hoping to get one when I got the Estate but were none around locally
Got the head checked over, a slight skim and 2 bent valves replaced also stem seals done, got gaskets and bolts so just needs refitting which I will do next weekend as I have afew weddings coming up so pump change this friday then head back on next once I have give the pistons and waterways a clean out
I can't find a sedan anywhere!
and that temp engine looks nice
Engines almost ready to refit had new HG, Valves, Cambelt, TD04 going on, FMIC manifold, 11mm gov modded and ground LDA Bosch setup.
Had the subframe seam welded just to give some strength back as i am going to cut the bulkhead back just to make sure i have no issues with the turbo once it's in. (pics to follow)
Cleaned all the rust and shit from the enginebay and gave it afew coats undercoat just to clean it up really and some high temp paint for along the back(might have some before pics as it was driven tho fords and streams daily so had suffered abit.
Just setting the coilovers up on 306 topmounts tonight and the wishbones will have there new bushes in shortly. New wheel bearings and TRE both sides also.
Subframe will be refitted tomorrow along with undersealing of the front wheelarches, back will be done at some point also.
looks like you got a good layer on there kyle give me a shout when engines going in
Will do hoping to have it in soon, Just need to get a new topmount and that bottom one done and it can go in then, minus a gearbox anyway i am going to get some discs and cut the bulkhead to paint it tomorrow. Ye about 3 coats but to use the last of the tin as i needed a brush cleaning tin Lol
Turbo and fanimold on:
Engine in and gearbox follow:
Had to Dewastegate the TD04 as even with the bulkhead ground out it still pressed into it but luckily my plate press just against the flap arm so it "should" not open. If so only by a small amount which i can live with.
Afew clearance issues to sort. Whats the best way around this? Anyone route the top pipe differently or make up there own?
Oh also fitted a new sump gasket and painted the sump altho now its all scratched :glare:
OMG, Ph2 sedan, im jealous.
I almost bought a ph2 but it was green and the draw of another bianca and a bosch pump was just too much
Been waiting for you to update this, looking good fella.
That turbo pipe is supposed to go through the inlet manifold, like up between the 1st and 2nd runners and then out the drivers side.
Edit, on the fourth photo you can actually see where the pipe rubs slightly on the 1st runner when it's routed properly :-)
I asked afew people that have xantia manifolds they said it goes round the side. I did try squeeze it tho but it was tight
(13-11-2012, 05:50 PM)HDIkyle Wrote: [ -> ]I asked afew people that have xantia manifolds they said it goes round the side. I did try squeeze it tho but it was tight
they will fit through the mani like stock iirc you need to take a grinder and shave abit of the support then clock the turbo around more and it will fit easy
Cooler might be better turned 90 degrees clockwise so the pipes go down the side of the radiator? Bit tight getting them over the top.
Cant believe your putting a ph1 front end on this. Ruined.
Phase 1 is the best. Outside anyway. Wanted to keep a phase 2 dash. And naa going to cut the slam panel the pipes will go straight over the top, that was the idea to start with
Got MOT tomorrow so should pass i hope.
Fitted amps and speakers:
Bumpers and lights all looks pretty sweet now its together:
Painted the headlining and all the grey trims also fitted black cabby sunvisors:
Needs lowering on the rear but 1 of the bars wouldnt come out also the suspension is rock solid no bounce whatsoever so that needs some attention also:
You've missed a hell of a lot out Kyle!
(12-05-2013, 01:38 PM)Tom Wrote: [ -> ]That interior is maaad!
Tbh the car is quite tame for Kyle atm!
