iv got a massive problem with my dials, all the lights work on them but the speedo, rev, fuel and temp dont work
iv tried a dial change but that still hant changed anything and im now really stuck
can someone help me please????
Fuses? Wires going to the plugs?
What else have you done to the car? Or did they randomly stop working?
Dont know if Jake mentioned it to you yesterday mate, but might be worth checking the earth for the clocks in the drivers side footwell.....
Edit, and Connor, they stopped working after the previous owner fitted an amp/sub in the boot, bit odd though isnt it, surely related but I cant see how..... :think:
Id check the plugs, and every fuse/relay, and then earths. Check over the loom and check condition of cables, fitting a sub/amp might have burnt something out if something wasn't done right
Matt Wrote:Id check the plugs, and every fuse/relay, and then earths. Check over the loom and check condition of cables, fitting a sub/amp might have burnt something out if something wasn't done right
Thats what I thought, maybe connecting the amp up with the battery still connected put alot of amps through the whole circuit/system and has melted an earth wire somewhere....
My point exactly, when someone's been f*cking around with the power supply, check all fuses first, easiest thing to do, then can either test for a supply at the clocks and if there's 12v there, then check the earths
Dan I think that's what happened. Some strain somewhere and melted cables lol
dan im gunna need your help asap then!
4WayDiablo Wrote:Meow
What?
power cable goes direct to battery and the earth is to a seat bolt IIRC. the cars playing up because it misses london
I reckon its gotta be an earth cos IIRC the different dials have different live feeds.
all sorted now
was just a fuse that someone said they had checked!!!
