I have a GTi6 fitment K&N cone filter.
Is the correct GTi6 version with fitting bracket on the end.
Good condition.
£45 delivered.
Bump
Would it fit a 1.4 meridian?
No idea. It's 76mm ID if that helps
no haha didnt know if need a turbo or anything for these. completely new to cars
Don't think it'd fit directly unless you bolted the cone straight onto the throttle body, the 6' body is at the front whilst the 1.4's body is at the back of the engine
With adapters or step down pipework from ASH (auto silicone hoses) or the likes you could effectively make it fit anything.
I had it coming straight off the '6 inlet with a silicone hose to keep it away from the floor and so it was poking out behind the headlight as I ran with the light removed on track.
Going to throttle bodies now so have no use for it.
