Right I'm a bit stumped by this one.
Fitted newish wishbones (known good ones from my previous car) had tracking done, wheels balanced and yet it still pulls to the right.
Any ideas?
Is it only pulling that way since you fixed your PAS yesterday?
Nope. Been doing it for a while. Thought it might of been due to the ram but fitting the new one hasn't fixed it
Have you checked your tyre pressures?
Car is clearly fascist...
(08-07-2012, 11:33 PM)Connor Wrote: [ -> ]Car is clearly fascist...
:flol:
Mine is also doing this, only when breaking. Think it's due a break imbalance/crappy droplinks
Was the tracking actually done, or did they just tell you they had? because to me that sounds like either a soft tyre on the front right or the tracking, if they had done the tracking properly everything should be straight and correct so it can't really be related to suspension components being out of line!
Just another thought, the bottom of your hub isn't ovalled out is it allowing the ball joint to move around?
I agree with Scott, it's just f*cked.
Having said that, since changing the wishbones on my '6, I know get a loud clunking noise below the driver's side footwell well pulling off and sometimes breaking.
Stupid french cars!
I have that sound when I reserve quicky or let off quickly after accelerating.
I would have said bad tracking to be fair.
Have you swapped the rear beam over from your old steed?
Haven't checked tyre pressures (miss simplest of things eh?)
Tracking was definitely done. I watched him do it and saw the end result and it was fine.
Rear beam is the original gti one with new standard mounts.
Fitted new wishbones and I'm 99% sure the hub was fine. There was no play at all.
Any brakes binding at all? Front right as thats the way its pulling?
Not that I'm aware of Tom. Front calipers are fine and rears are shot but I'm positive there not binding.
Fair enough, everyones running out of ideas now I think lol. :/
(09-07-2012, 04:56 PM)Toms306 Wrote: [ -> ]Fair enough, everyones running out of ideas now I think lol. :/
swap the 2 front wheels from side to side (left with right)
once a tyre has started conical wearing , no matter who/how/when you check the tracking it will still pull over.
by putting tyres onto opposite sides of the axle, it will counteract the wear and drive straight.
I need to swap my fronts over. I keep having the tracking donebut its soooo annoying having to stop your car drifting onto the other side of the road. No usual tracking induced tyre wear either. :/
(09-07-2012, 05:55 PM)daddyfixit Wrote: [ -> ] (09-07-2012, 04:56 PM)Toms306 Wrote: [ -> ]Fair enough, everyones running out of ideas now I think lol. :/
Great idea but t1rs are directional tyres so they will be spinning the wrong way....I think. Too much strongbow to think about it!
maybe somethings rusty?
trololol
everyones said what i can think of, so figured id troll.
if the tyres are directional , you will have to swap the tyre off the rim then
or swap front to rear on the same side ?
My new one is doing this. got it tracked up and did tyre pressures and still no difference...ill swap the tyres around this weekend.
i guess i could swap the rear and the front around to see if it makes a difference?
(10-07-2012, 08:16 AM)Ben Jay Wrote: [ -> ]My new one is doing this. got it tracked up and did tyre pressures and still no difference...ill swap the tyres around this weekend.
Hmmmmm................I shall quote the post above yours..........not really sure............
(10-07-2012, 07:12 AM)daddyfixit Wrote: [ -> ]if the tyres are directional , you will have to swap the tyre off the rim then
didnt see daddyfixits post haha
ill give that a go tonight when i get back and see if theres any difference
(10-07-2012, 08:21 AM)Ben Jay Wrote: [ -> ]didnt see daddyfixits post haha
Can I suggest that you read threads properly before posting silly questions that have already been answered
(09-07-2012, 05:55 PM)daddyfixit Wrote: [ -> ]once a tyre has started conical wearing , no matter who/how/when you check the tracking it will still pull over.
This. Unfortunately, if this doesn't fix it, then you should be looking for crash damage around the chassis.
Have you tried changing the top mounts on the front struts? mines pulling to the right so much it hurts my arm on long journeys, and i know for a fact the drivers side top mount bearing is falling apart.
Just another thing on the to do list
Wishbone bush's or ball joints.
Right top mounts have only done about 10k, same as wishbones but there on their way out. I still reckon it could be that my beam isnt aligned but will straighten it up tomorrow and see.
They can't be aligned, the sit in a set place.
