11-08-2012, 07:52 AM
11-08-2012, 10:17 AM
Looking good
I got those pedals the other day for mine, did you fill yours with the grease they gave you? I wasn't sure the guy in the shop said something about it so I just did it to save the bearings.
11-08-2012, 10:26 AM
Yeah I did mate. I think they come pre greased but my last set lasted 30 seconds so just packed them full
12-08-2012, 07:20 PM
So finally finished except a decent set of tyres.
Had a issue with the front brake. The older marzocchi forks with IS mount for some stupid reason, had the mount offset slightly. Hope used to sell an adaptor for this but not any more so I'm left with....
Now getting hold of some 6mm steel to make a adaptor on a Saturday afternoon wasn't possible so a quick trip to screw fix and a temporary fix is sorted..
Problem solved. For now!
Anyway on to today and the first proper ride. Started early this morning with a brake fluid flush as it was discusting and shorten the chain slightly.
Dog approves...
First ride was to leith hill in dorking and within 5 minutes we already have to stop
One of the view
And then usain bolt joined us...
Bike rode well. Forgot to set up the rear mech so could only get 8 gears and the seat post I got was far too short for my liking for XC'ing between trails.
Forks I wasn't so impressed with. Filled with air to the recommended pressures for my weight and they were ridiculously stiff and the rebound was insane. Had a worrying knock as well which I thought could be a worn bush that the seller didn't tell me about but dissapeared after I adjusted the pressures when I got home.
f*ck me i didn't realise how unfit I was! Well worth it though. Great day
Dog approves...
One of the view
12-08-2012, 08:27 PM
But, but, bombers are amazing and manitous are just shit...
She ride well otherwise bud?
12-08-2012, 09:22 PM
Lovely. Only thing is the front was really really lively but think that's down to skinny shit tyres and mental rebound.
14-08-2012, 03:13 PM
What's the geometry on the frame?
14-08-2012, 06:38 PM
Sizes:
15.5", 17" & 19" (measured from centre of BB to top of seat tube)
Tubing:
Reynolds 725 double butted & heat treated cro-moly front triangle, ring reinforced cro-moly head tube, 4130 cro-moly seat stays and chain stays
Effective Top Tube Lengths:
15.5" frame = 22.5"
17" frame = 23.25"
19" frame = 24"
Head Angle:
70 degrees
(recommended travel 120mm to 140mm)
Seat Angle:
74 degrees
Chain Stay Length:
16.73"
BB Height:
12.76"
Seat Post Size:
27.2mm
Seat Clamp Size:
30mm (29.8mm may also fit)
Front Mech Size
28.6mm top pull
BB Shell:
73mm
Max Rear Disc Size:
185mm
Colours (subject to change without notice):
Pearl Orange and Kawasaki Green
Tubing:
15.5" frame = 22.5"
17" frame = 23.25"
19" frame = 24"
Head Angle:
70 degrees
Seat Angle:
74 degrees
Chain Stay Length:
16.73"
BB Height:
12.76"
Seat Post Size:
27.2mm
Seat Clamp Size:
Front Mech Size
28.6mm top pull
BB Shell:
73mm
Max Rear Disc Size:
185mm
15-08-2012, 05:32 PM
That's an xc-orientated geometry set-up, so it'll push you over the front end, could be what makes it seem more twitchy. Have you been used to more relaxed downhill/bsx/dj stuff before..?
15-08-2012, 09:55 PM
No it's identical to my last frame ....well except colour! I think it's the tyres. Them panaracers are hateful things at the best of times!
16-08-2012, 01:38 AM
You lost me at "double butted".
16-08-2012, 05:40 AM
Fair enough, guess the forks really are that stiff then lol.
