24-06-2012, 08:48 AM
So, Swapping my engine on the weekend of the 7th/8th. Like for like, xu7jp4.
While I am there, I was intending to get a couple of little bits done while there is the extra space. Just wanted to bung my shopping list up incase I have overlooked anything and anyone would be so kind as to rectify my mistake
Engine Swap: In no particular order
Engine Mounts
Gearbox Oil
Engine Oil
Exhaust Fire ring
Exhaust manifold wrap (going to be putting '6 mani on)
Head Gasket
x4 Valve guide seals
Bottom rad hose seal
Driveshaft seals
Coolant
Inlet gasket
Exhaust Gasket
Cambelt
Rallye Aux belt setup (removing aircon)
Clutch arm bushes
New pinch bolts for lower arm ball joint (putting eccentric top mounts on)
Gear Linkages
Front wheel bearings
A shit load of patience
IIRC the engine has a new 'stat, water pump and belt tensioners on it. Needs 2 valve guide seals replacing, hence some of the parts above...
If anything sticks out that I've forgotten please lemme know
Engine Mounts
Gearbox Oil
Engine Oil
Exhaust Fire ring
Head Gasket
Driveshaft seals
Coolant
Inlet gasket
Exhaust Gasket
Cambelt
Clutch arm bushes
Gear Linkages
