Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
(09-12-2014, 12:38 PM)Toms306 Wrote: [ -> ]Why is the flat one flat? Punctured or damaged rim? They shouldn't just go flat from standing really.
I was desperate to get them fitted as the old ones were illegal. On a monday all I could find was a guy who put them all on and didnt balance them or clean up the rim before hand. Ill be taking them all to the garage to get them refitted and balanced.
Sounds like an excellent job lol, hope it was cheap!
(09-12-2014, 12:45 PM)Toms306 Wrote: [ -> ]Sounds like an excellent job lol, hope it was cheap!
it was so very cheap....
Ordered another egr blank. I'm not sure where the first one I bought is. This one is also the slot in type so should be easier to fit. Once its arrived the inlet elbow can be fitted along with the egr.
Hopefully the wishbones will arrive so I can get those done this weekend along with fitting the interior and giving it all a good clean.
Do people still buy blanks!?
I can supply you a brand new brake pad from a set that I had to buy when one in the back of the rallye decided it liked the M5 tarmac better than the rallye calliper.
Why wouldn't I buy a blank piggy? Just make one myself? For 3 quid I'm not complaining.
Chris thst may come in handy mate. I'll let you know at the weekend but the 4th must be in there somewhere!
Here is the last MOT. Hopefully Ive got everything to fix it now!
Yeah I just assumed you would make one, spose £3 is ok.
I think it was gatebridge motor services that gave my shockingly rusty 106 nad an MOT
I really can't see the point spending an hour or so making something to save £3. That's like 30 miles max in a frugal diesel, probably only about 15 miles of petrol in Sams 1.8.
Have you got a new droplink as well Sam, it's on the advisories but they're so cheap you may as well do it at the same time as the wishbone.
Not sure about steering rack inner joints, never touched them myself, but if you're getting it tracked it makes sense to change them also, price dependant of course.
(10-12-2014, 09:14 AM)Toms306 Wrote: [ -> ]I really can't see the point spending an hour or so making something to save £3. That's like 30 miles max in a frugal diesel, probably only about 15 miles of petrol in Sams 1.8.
I have 'A' new drop link. No idea about steering rack inner joints.
Steering rack inner joint are easy with the right tool. But ive done them with mole grips before just a fiddle.
Please don't start replacing suspension parts only on one side of the car...
Getting one of the rack end boots off is a bit more fun than you'd of thought if you've not done one before
EGR Blank and Meyle HD wishbones have arrived!
Two right? Tell me you bought two?
(13-12-2014, 07:03 AM)Poodle Wrote: [ -> ]Two right? Tell me you bought two?
Yes. When you add s onto the end of something it means multiple of. I.e more than one. X
This not back on the road yet? Whats the hold up?!
Times like this i wish i was closer to other members, I'd be more than willing to come and lend a hand, even if I'm not the most adept mechanic in the world.
Hopefully ones a left...
(13-12-2014, 10:20 AM)WiNgNuTz Wrote: [ -> ]This not back on the road yet? Whats the hold up?!
Don't be silly mate you were so helpful with your clutch change
Just checking, just checking. LOL Tom, good point, that could have been embarrassing.
Reckon she'll be back on the road after Christmas then dude?
So today I went to grans and made a start. Found all the seatbelts and bolts etc which had previous been stripped when the buckets were fitted. I fitted the EGR blank and put the elbow back together. Bit of a blow there but Ill treat it to a new gasket when it passes the MOT. Drove the car out onto the drive so we could start work on it.
Tom arrived. We disconnected everything from the subframe and dropped the subframe out. We then removed the ARB and clutch cable mount and fitted it to the new seam welded subframe. Reason to swap subframes was that I had this one spare and one of the self retaining nuts of the old one had come lose and couldn't be undone or done up! Not many photos but we ended the day with the seam welded subframe back on the car with the two bolts.
Hopefully during the week Tom will be able to pop down and remount the steering rack and bolt the rest of the subframe on along with the new wishbones.
Nice!!
If you get a egr gasket, grab me one, I'll send ya da £zz
Much plans for it this weekend?
Sam's busy most of the weekend, I'm hoping to get over though. Also think the replacement beam is being delivered today or tomorrow.
Welcome to the seam welded subframe club
So after fixing the 3L I drove round to my grans. One of the last days I can work on it before Christmas day and its not fair to have a car in pieces on stands taking up the drive when she has relatives staying.
Anyway I arrive and tom was already there. The ball on the subframe was wedged between a boost pipe and the cat so we dropped the subframe again and redid it. Did up all the bolts. Tom put the rack and gear linkages back on whilst I put the wishbones on. All back together now minus the ARB bolts and drop links. Wheels back on a and its all back under shelter for Christmas!
So I need to...
Find bolts.
Order beam.
Fit interior.
Refit battery
Order wing and fit.
