27-02-2020, 11:00 AM
29-02-2020, 07:18 PM
They aren't that simple to check.
You could compare two at constant revs say at idle and 3k rpm via the volts out on pin 5 for the flow or the volts on pin 1 for the temperature volts out.
05-03-2020, 02:53 PM
Thanks, got that info from a HDI file in info, real good info..........will be checking 12v supply ( suspect make and break contact in wires...... ) and earth and outputs...........awaiting turbo oil return pipe, £40 from pug with discount!!
